Which way to install pilot bearing NV3550? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Which way to install pilot bearing NV3550?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSuper Low Prices on TJ Bumpers and $399.95 Tire Carriers!Northridge4x4 - Memorial Day Sale
Unread 04-18-2006, 03:05 PM   #1
rollerized
I'm not sure which way the pilot bearing goes in on the NV3550. One side of the bearing is stepped down and the other side is bevelled. anyone know? It probably doesn't matter but wanted to make sure. thanks
rollerized is offline   Reply With Quote
Unread 04-18-2006, 03:30 PM   #2
Bob_R
Assuming we are talking about the bearing that goes into the aft end of the crank where the transmission mates up, the side with the two notches in it go toward the crank or front of vehicle. this is so you can again get it out with a tool designed just for this purpose. Or as you stated a step down on the inside of the bearing to let the tool grab onto something to pull it out again when needed. Lightly grease it don't use a lot of grease.
[B][COLOR="Yellow"]GROWING OLDER IS MANDATORY, GROWING UP IS OPTIONAL[/COLOR][/B] [COLOR="DarkRed"]TREAD LIGHTLY[/COLOR]
Bob_R is offline   Reply With Quote
Unread 04-18-2006, 04:25 PM   #3
rollerized
Yep thats the bearing. Great! Thats the info I needed, Thanks for the response.
