Waterpump tutorial - Page 2 - JeepForum.com
post #16 of 30 Old 03-29-2011, 07:21 PM
Karsten
Originally Posted by letitloose06 View Post
You can by the pipe from RockAuto Auto Parts
It's called a "Water Pump Inlet Tube"
DORMAN Part # 56398
i bought it today from a Jeep parts department
they call it: Tube-Water 1B7F
Part No: 5300 7978
List Price 30 , i got it for 16
a bit pricy but convenient (if in stock)
Karsten is offline
post #17 of 30 Old 07-13-2011, 04:05 PM
er2ergrn
I know this is an older posting but to answer previous persons question about how to tell before removal. According to the service manual it only states it on the impeller which is only visible when removed. I have seen it on here somewhere that says which years are reversed and which are forward spinning. Also you need to get the routing for the serpentine correct because apparently you can reverse the coolant flow because of this. I didn't know I could put the belt on reversed and don't want to try either. LOL
er2ergrn is offline
post #18 of 30 Old 07-14-2011, 01:12 PM
Flajeeper1
1987 YJ Wrangler
I added a 140 amp alternator recently to my 87' 4.2. It uses a narrow V-belt pulley and even with a new belt has a tendency to squeal. The alternator shop said that the best way to fix the problem is to change to a serpentine belt. My question is if I change to the serpentine belt I need to change the water pump to a reverse rotation. As I understand it the reverse flow will work ok. Any thoughts? Has anybody done this before?
Flajeeper1 is offline
post #19 of 30 Old 07-14-2011, 01:48 PM
plym49
Are you saying that you need a wider groove v belt pulley? If so, I don't understand why the alt shop could not just give you a different pulley.
plym49 is offline
post #20 of 30 Old 07-14-2011, 01:57 PM
Flajeeper1
1987 YJ Wrangler
The pulley for the alternater on the crankshaft is also narrow. I have the parts available to do the changeover except for the waterpump. Is there a replacement V-belt pulley for the crankshaft that is wider?
post #21 of 30 Old 07-14-2011, 02:02 PM
plym49
I would guess the answer to be yes, given that that motor dates back to Rambler. Or perhaps you could modify something from a junkyard. I have a feeling someone like Max will reply with a part number.
plym49 is offline
post #22 of 30 Old 07-14-2011, 02:46 PM
Flajeeper1
1987 YJ Wrangler
Max? Chime in here with your wisdom.
post #23 of 30 Old 07-14-2011, 02:53 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Okay, you can switch from a V-belt to a serpentine belt. You will need a 6 groove pulley for every accessory item that is driven by the belt, except the waterpump. You will need a smooth, wide, waterpump pulley specifically for a serpentine belt equipped 4.2L and a 6 groove serpentine style harmonic balancer for the crankshaft. You will also need 1 smooth idler pulley for a YJ without a/c, or 2 smooth idler pulleys for a YJ with a/c on it.
The smooth pulleys (idler pulleys & waterpump pulley) are smooth because their contact with the belt is on the non-grooved side of the belt. Picture a circle representing the belt with the grooves of the belt facing inside the circle. The pulleys are located inside this circle where they ride on the grooves. If the circle turns clockwise (like your engine rotates) the pulleys contacting the grooves will turn clockwise also. However, if a smooth pulley rides on the outside of the circle, it will rotate counter-clockwise. This is why you will need a reverse rotation waterpump.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #24 of 30 Old 07-14-2011, 04:07 PM
imstillatwork
DANG... no hesitation at all. Call and he appears! I'm starting to think he is a JEEP not a person...
imstillatwork is offline
post #25 of 30 Old 07-14-2011, 05:50 PM
Flajeeper1
1987 YJ Wrangler
Max, the other question is: Is it better to change to a serpentine belt system or is a wider pulley available to replace the crankshaft pulley and would the wider belt work well with the larger alternator and not squeal? (this would be an easier solution)
post #26 of 30 Old 07-18-2011, 08:21 AM
Flajeeper1
1987 YJ Wrangler
Anyone have information on if a wider crankshaft pulley was available for the alternator belt. Mine has the really narrow pulley.
post #27 of 30 Old 07-18-2011, 12:57 PM
plym49
I would be really surprised if there was not a wide-belt crankcase pulley available for these motors. Check the CJ forum, or perhaps American Motors/Rambler forums. It is likely that earlier incarnations of this engine came with wider pulleys. Also try the aftermarket companies.
You might also be able to install dual v-belts.
plym49 is offline
post #28 of 30 Old 07-22-2011, 08:34 AM
Flajeeper1
1987 YJ Wrangler
Thanks for the suggestion.
post #29 of 30 Old 06-12-2013, 12:59 PM
AW-100
1987 XJ Cherokee
Old thread, but new info:
http://jeep-manual.ru/index.php?page=85
Here you can see the routing with V-belt and serpentine.
AW-100 is offline
post #30 of 30 Old 07-14-2013, 08:25 PM
JEEP_Nut1218
Just wanted to chime in and say thank you for this incredibly useful information. It saves me a lot of time and head ache
'90 YJ with some stuff
I'm a pic whore, get over it.
JEEP_Nut1218 is offline
Newbie Search Tutorial Unlimited04 TJ Wrangler Technical Forum 3 03-25-2009 07:45 PM
Search Function Tutorial Unlimited04 Wrangler General Discussion 2 03-25-2009 07:29 PM
Spray Paint Tutorial? mknherhappy TJ Wrangler Technical Forum 2 05-23-2008 10:31 PM
Lifting tutorial? cuvvyschultz JK Wrangler Technical Forum 2 04-01-2008 12:03 AM
How To/Tutorial Video About Dual Top scottlaroc JK Wrangler Technical Forum 4 05-21-2007 05:51 PM
