waterproofing electrical - JeepForum.com
post #1 of 18 Old 02-23-2014, 03:59 PM Thread Starter
jhrebs
1987 YJ Wrangler
I am sick and tired of everytime it rains water pours into my dash and my radio goes crazy. What have some of you done to protect your radio from rain? I very rarely put my top up in the summer and this has been an ongoing problem. I have been through several "marine" radios.
First I am going to follow the steps in the write-ups to track any leaks. Then I was thinking off removing my entire dash and line everything with heavy duty plastic. Basically making a bag to cover everything and leave the bottom open. What do you guys think about this?
I am getting ready to add a cb radio so this problem has been brought to the fore front.
Once again, thanks guys for your help.
'87 reg. historic, 2" bds springs, 1" boom shackles, 1" daystar BL, 31" Intereco trxus, Crager soft 8's, steel braided brake extensions, monsta liner
jhrebs is offline
post #2 of 18 Old 02-23-2014, 04:01 PM
Richard_
tuffy center console with stereo compartment
Richard_ is offline
post #3 of 18 Old 02-23-2014, 04:04 PM
jay-h
The Tuffy is a good solution. A quick and dirty solution is install a plastic sheet above the radio.
My leakage turned out to be that seam in the cowl just in front of the windshield. Sealing that up with waterproof silicone caulk resolved the leaking.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #4 of 18 Old 02-23-2014, 04:18 PM
Richard_
if you heven't read this water under dash , you need too
Richard_ is offline
post #5 of 18 Old 02-24-2014, 03:56 PM Thread Starter
jhrebs
1987 YJ Wrangler
Thanks Richard, I will be performing these as soon as it warms up. An guys, I have seen those Tuffy boxes. I was hoping to hear some outside the box thinking.
jhrebs is offline
post #6 of 18 Old 02-24-2014, 06:43 PM
NHfireLJ
NHfireLJ's Avatar
Fix the leak
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #7 of 18 Old 02-24-2014, 09:38 PM
bill8bud
I sealed RC car electronics with platidip spray on. I had to take the electronic parts down to the board level to seal them.
That would be outside the box.
I bet it would be easier to fix the leak. I like the plastic defeltor idea.
bill8bud is offline
post #8 of 18 Old 02-25-2014, 04:28 AM
jay-h
The potential problem with sealing electronics is that some components may overheat. There is a reason radios etc are vented.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
jay-h is offline
post #9 of 18 Old 02-25-2014, 06:12 PM
brianandcara
1987 YJ Wrangler
Cut a vent in the bottom of an old ammo can and mount your electronics in it, add a cooling fan if you need, then bolt that in place of your middle console, lockable and waterproof as long as the gasket is good, plus you can slip the lid off the hinge and lay it under the seat while your using it. You'll have to make some brackets to mount it at whatever angle you want it to sit. Maybe mount two small ones instead of one big one then you have one for electronics and one for storage. I've heard that the 50 cal and 20mm boxes are about the biggest that fit. Not out of the box thinking, just different box thinking.
My build thread
http://www.jeepforum.com/forum/f22/87-laredo-renix-4-0-ford-8-8-fresh-paint-2112993/
brianandcara is offline
post #10 of 18 Old 02-26-2014, 09:28 AM
Why J?
Why J?'s Avatar
Usually water gets to the radio from 2 places. The first place is the face of the face of the radio itself. The only fix for this is a marine grade radio. The second place is from the center gauges. Water gets behind the dash from the space between the gauges face and the dash cover. Jeep uses a plastic shelf that is held in place by the gauges that redirects this water forward away from the radio. Which works for the most part. But people usually discard this piece when they take the center of the dash apart or the piece gets brittle and brakes.
I'll bet the OPs OEM water shield is not installed.
New Project "Pissed Wife"
Phase II 5.3L/4L60e then NV3550
Why J? is offline
post #11 of 18 Old 03-02-2014, 12:25 PM Thread Starter
jhrebs
1987 YJ Wrangler
Why J? i will take a look at this when i start digging. Maybe post some pictures. Do you have any experience with this?
jhrebs is offline
post #12 of 18 Old 03-02-2014, 08:26 PM
Why J?
Why J?'s Avatar
I don't have pics. I'll loot on google and post back if I find some.
I have pulled my dash on several times and have pulled the dashes on other YJs several times in the last to replace radios and what not. It is fairly obvious the purpose of the shield when you see it in the dash.
My dash gets rained on all the time and my radio never gets wet.
Why J? is offline
post #13 of 18 Old 03-02-2014, 09:17 PM
Why J?
Why J?'s Avatar
Here ya go. Photo by Mean Max
Why J? is offline
post #14 of 18 Old 03-03-2014, 01:09 AM
jojojeep1
spray all your wires with wd-40 it shed's the water.
jojojeep1 is offline
post #15 of 18 Old 03-04-2014, 06:43 PM Thread Starter
jhrebs
1987 YJ Wrangler
Yeah I dont even have to pull my dash off again to know I dont have that! I am really trying to analyze that picture to see if I can fab something like it. Any help would be great. I am going to google it some more.
jhrebs is offline
