Waterproofing Ax-15 - JeepForum.com
post #1 of 2 Old 10-20-2007, 03:47 PM Thread Starter
Douglas S.
Waterproofing Ax-15
I have an external slave ax-15 () sitting on my garage floor right now. What should i do to waterproof it before i put it in the jeep?
Thanks
1991 Land Cruiser HDJ81
Douglas S. is offline
post #2 of 2 Old 10-20-2007, 06:54 PM
Alfons
The clutch would be the most work to waterproof (lots of holes around & on the bell housing), but if you look things over carefully & install a good vent, you can probably do it. The AX15 is pretty well sealed except right at the top - the shifter hole is open. If you seal this up, you should also consider adding a vent.
Alfons is offline
Waterproofing a TJ IH8ROADZ TJ Wrangler Technical Forum 15 01-25-2008 06:23 AM
Waterproofing jappe TJ Wrangler Technical Forum 3 01-15-2008 01:17 PM
waterproofing 95YJnh YJ Wrangler Technical Forum 8 07-01-2005 05:10 PM
waterproofing sebax TJ Wrangler Technical Forum 1 05-31-2005 11:39 PM
Waterproofing a TJ?? nooch13 TJ Wrangler Technical Forum 6 08-28-2004 08:20 PM
