post #1 of Old 07-19-2013, 11:48 AM Thread Starter
PJGC
Water Pump Replacement
my 95 YJ 2.5L has a serpentine belt with an old style power steering pump, reservoir is mounted to the radiator. the bracket that holds the power steering pump and the serpentine belt tensioner has two bolts that go through the water pump and the back side of the bracket is in between the engine and the engine mount. the engine mount bolt goes through the back side of this bracket, bazar.
My question is has anyone with this setup changed their water pump and if so how do you get this bracket out of the way so you can remove the water pump; short of putting a jack under the engine and taking the bolts off of the engine mounting bracket?
PJ
PJGC is offline
You may not post new threads
You may not post replies
