Water pump removal - JeepForum.com
post #1 of 2 Old 09-25-2001, 10:15 AM Thread Starter
D
Water pump removal
My friend has a 94? Wrangler with the 2.5L? engine. He is trying to pull the water pump but can't get the fan and the pulley off. Is there a certain way to remove the fan and pulley? He has removed the four nuts that appear to hold the fan on the pulley but nothing seems to want to come off.
D is offline
post #2 of 2 Old 09-25-2001, 01:56 PM
JeeperJay
Those 4 bolts are the only things holding the fan/pulley on. Chances are they are probably just rusted together. Just use a little brute force and they should come off. Also take the tension off the drive belt if you haven't done so already.
1992 YJ, 2.5L 4-banger, 2" Lift, 31x10.5 BFG Mud Terrain, K&N Filter, Restrictor Removed, Hi-Lift, Custom bumpers, More to come...
JeeperJay is offline
YJ Water Pump Heater Intel Tube Removal guamlenahans YJ Wrangler Technical Forum 2 12-24-2009 09:01 PM
4.0 Water Pump Pulley Seized onto water pump grAmit TJ Wrangler Technical Forum 9 09-09-2009 05:17 PM
Heater hose tube removal from water pump JoshuaZ TJ Wrangler Technical Forum 1 04-18-2009 12:20 PM
water pump pulley removal Ryno YJ Wrangler Technical Forum 5 09-26-2005 12:47 AM
Water Pump, best one???? NomadJeep YJ Wrangler Technical Forum 7 02-18-2003 09:24 AM
