Water pump question. - JeepForum.com
post #1 of 12 Old 06-02-2013, 09:08 PM Thread Starter
87laredo
1987 YJ Wrangler
Hello all,
I am in need of a new water pump and water pump pulley. My question is what is the difference between a (integral pipe) water pump and a (non-integral pipe) water pump? Which one is factory? And what places sell a water pump pulley because none of the auto parts stores around here ( north west Ohio) sell them??
Thanks
Jake
87laredo is offline
post #2 of 12 Old 06-02-2013, 09:40 PM
bigbossd1030
Originally Posted by 87laredo
Hello all,
Thanks
Jake
I am pretty sure the integral pipe one is the one that has the fitting on it for the heater core. It should cost more for this one. And the non integral pipe is the one that doesn't have it. I personally would get the one with the pipe as it was hard for me to find a replacement one. Plus if you don't need it, keep it just in case. As for the pulley, are you sure you need a new one, I am pretty sure it is just a bolt on like mine was.
Sent from my iPhone, probably because I am bored at work.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #3 of 12 Old 06-03-2013, 04:41 AM
superj
you have to get hte pulley online, they are hard to find.
the integral pipe and non-integral are the same pump, just one the pipe is pressed in place, if i remember right. i had to unscrew my pipe and screw it into the new water pump.
also, when you buy your new pump, fellow 87 owner (i learned this the hard way), take your old one and lay it on the bench next to the new one and measure to make sure the pulley mounting surface is the same height on both. there are 3 or 4 water pumps that the store will show fit yours and you will probably have to go to a few parts places to find the right one. the blades on the impeller need to be facing the right direction and the heights need to be the same so make sure they are identical or you will be back and back and back
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #4 of 12 Old 06-03-2013, 05:51 AM
Rproject
1987 YJ Wrangler
THIS!
I too had to unscrew my pipe and thread it on to the new one. I put a touch of gasket sealer on the threads before I put it on, JIC. Also, YES, pay close attention to the impeller blades, size and bolt locations. Many places stock 87-95 water pumps thinking they're all the same. Most '87's are v-belt vehicles and the shops stock the serpentine belt unit. Completely different rotation between the two.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #5 of 12 Old 06-03-2013, 07:04 AM
superj
i ended up using one from a 90 or something because i have the serpentine belt with factory ac so my set up is different then a normal 87 model. if you have a laredo with ac, you will probably end up getting one from another year too
superj is offline
post #6 of 12 Old 06-03-2013, 08:08 AM Thread Starter
87laredo
1987 YJ Wrangler
Thank you everybody, btw mine is a stock 4.2 v-belt with AC. If that helps any.
Jake
87laredo is offline
post #7 of 12 Old 06-03-2013, 08:13 AM
Rproject
1987 YJ Wrangler
Jake
Have you been peeking under my hood again? That's exactly what I have. Laredo and all. I got my pump from Advanced Auto. They had it in their warehouse and had it to the store in under 3 hours. Direct bolt on (had to switch the pipe from mine to theirs). 2 hour job for a shade tree mechanic.
1996 White ZJ
Rproject is offline
post #8 of 12 Old 06-03-2013, 09:28 AM Thread Starter
87laredo
1987 YJ Wrangler
Sweet thanks very much everybody!
Jake
87laredo is offline
post #9 of 12 Old 06-03-2013, 10:11 AM
superj
hmm, both of ya'lls are laredos and you have v-belts? wow, thats crazy
superj is offline
post #10 of 12 Old 06-03-2013, 10:15 AM
Rproject
1987 YJ Wrangler
Whatever you do, don't go to Autozone. I had them arrange a 1 car funeral in the past, didn't turn out well.
1996 White ZJ
Rproject is offline
post #11 of 12 Old 06-05-2013, 09:43 AM Thread Starter
87laredo
1987 YJ Wrangler
Yes 4.2 has a v-belt and then when jeep switched to the 4.0 in came the serpentine belt.
87laredo is offline
post #12 of 12 Old 06-05-2013, 10:05 AM
superj
not on all of them. i know a couple 87,88, 89 YJs with a serpentine belt. mine is one and its all original but the block and a few internals for the stroker. but i have spoken to a number of people who all have serpentine on their 4.2. i think it is just luck of the draw to be with or without one and have the v-belts
superj is offline
