Water Pump Pulley - Studs vs no studs - JeepForum.com
post #1 of 24 Old 05-14-2010, 09:42 PM Thread Starter
SpideYJeep
Water pump leaked like a sieve during pressure test, left me with just over a gallon in radiator. Firestone wanted $400 plus to do it and one of the 'mechanics' was insisting that they replace my (working) tstat.
I dismantled everything with the pump ready to pull out (hanging by a heater hose) as it got dark...will wait for daylight.
Question - why does the original have studs on which the fan pulley will mount while none of the replacements at Autozone, Quadratec, NAPA, etc. show them in pics? How do I mount my fan now?
Wrenching isn't the problem, it's the brains attached to the hands...unfortunately, I'm lacking some of the former so that's why I'm asking you guys!!
Originally Posted by YJake View Post
My YJ is so excited it's leaking oil!
SpideYJeep is offline
post #2 of 24 Old 05-14-2010, 10:06 PM
dtn8tr
You need to remove the studs from the old waterpump. If you look at the instructions that came with the new waterpump it will say that. Double nut the studs and then turn them out. I just did mine today but it was leaking worse so I have to take back apart tomorrow...also got too dark to finish.
1997 TJ, 5" IRO front with 4.5" HD IRO WJ rear, 35x12.5x15 Mickey Thompson MTZ, JKS disconnects
dtn8tr is offline
post #3 of 24 Old 05-14-2010, 10:09 PM
nudosimmons
while its apart its always a good time to change the t stat
1988 xj 4.0, ba-10, np231
trimmed fenders
3in lift, 33s
herculinded interior
custom bumper
nudosimmons is offline
post #4 of 24 Old 05-15-2010, 09:51 AM Thread Starter
SpideYJeep
I can't pull the water pump past the steering pump. Any ideas?
post #5 of 24 Old 05-15-2010, 09:59 AM
dtn8tr
you need to take the bolts out of the bracket that bolt into the waterpump and make sure the other bolts for the ps pump are loose. Just took mine back out this morning...make sure you put the gasket on correctly otherwise the hole for the passage at the top left is offset slightly and will leak like a biotch!
dtn8tr is offline
post #6 of 24 Old 05-15-2010, 10:01 AM Thread Starter
SpideYJeep
never mind, muscled it past it. Now to the studs...
post #7 of 24 Old 05-15-2010, 10:02 AM Thread Starter
SpideYJeep
dtn8r, thx for the last suggestion, too. would be pointless exercise if she leaks again!
post #8 of 24 Old 05-15-2010, 10:09 AM Thread Starter
SpideYJeep
BTW, that PS bracket makes it a ***** to remove the WP. I'm sure it makes it difficult to install
post #9 of 24 Old 05-15-2010, 10:52 AM Thread Starter
SpideYJeep
replacement came with a gasket, looks like cardboard and no mention of self sealing or not. should I use RTV?
post #10 of 24 Old 05-15-2010, 01:11 PM
dtn8tr
Yes...rtv both sides...just finished mine and no leaks but I found out why it was running with no thermostat...the radiator must be shot! Temp gauge went to the red now when I took it out. Everything else is new! Arrrggghhh!
dtn8tr is offline
post #11 of 24 Old 05-15-2010, 10:06 PM
WhiteYJLA
I just bought new studs at Autozone. They have a kit with the studs and nuts that go on them for the fan clutch. I think the kit was $5.
I used that aviator gasket maker on mine so I didn't have to wait for the RTV to setup before filling the system up.
WhiteYJLA is offline
post #12 of 24 Old 05-16-2010, 06:52 AM Thread Starter
SpideYJeep
Took Dtn8r's advice, studs were easy to switch off of old onto new pump.
I forgot to look for that...next time!
post #13 of 24 Old 05-16-2010, 06:55 AM Thread Starter
SpideYJeep
sorry to hear that
post #14 of 24 Old 05-16-2010, 01:26 PM Thread Starter
SpideYJeep
As the nuts and studs are between the fan clutch and pulley, how do you set the torque? I can't fit a ratchet or torque wrench in that space!
Also, what are the torque settings for the power steering pump mount bolts?
post #15 of 24 Old 05-16-2010, 02:39 PM Thread Starter
SpideYJeep
27 N.m for the power steering bolts (all)
4.0 Water Pump Pulley Seized onto water pump grAmit TJ Wrangler Technical Forum 9 09-09-2009 04:17 PM
Water pump pulley berman95 YJ Wrangler Technical Forum 7 08-10-2008 08:45 PM
Water pump pulley 426Savoy YJ Wrangler Technical Forum 12 03-09-2008 06:37 PM
Replacement fan studs for water pump mhenry79 YJ Wrangler Technical Forum 2 07-21-2006 05:30 PM
water pump pulley removal Ryno YJ Wrangler Technical Forum 5 09-25-2005 11:47 PM
