Water Pump + Prestone Flush = Jeep Fountain - JeepForum.com
post #1 of 2 Old 04-27-2010, 02:28 PM Thread Starter
BAJER-guy
2011 JK Wrangler
So I had a small hose leak on lower radiator hose, figured I'd throw in some Prestone Leak Stop (The big bottle, not little one with black stuff in it).
Followed directions completely to the letter, and it didnt work.
So I decided to flush the system out with the new Prestone Flush Kit (That instructs you to splice the upper hose and fit with a garden hose attachment).
That worked as it would have.. it cleaned out all kinds of mud and gunk from my system. Very cool. However... (there's always a down side isnt there).
After doing the flush, I now have a MEGA leak from my water pump AND my radiator hose. I took the hose off, turns out there is a little warping of the rubber at the end of it which creates the little leak it has.
So anyways, now I've got this huge leak and I need to know if I need to get a whole new water pump or if I can just seal it with something (RTV or Silicone?)
I'd really not like to spend a ton of money on a new water pump ($140 on Quadratec, fancy one?) Any tips or advice from the sages?
BAJER-guy is offline
post #2 of 2 Old 04-27-2010, 02:45 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Why not use this one? Original Replacement Parts 4626054 - Water Pump for 91-01 Jeep® Wrangler YJ & TJ with 4 Cyl & 91-01 Cherokee XJ with 2.5L Engine - Quadratec
And pick up a lower and upper radiator hose at the same time since you are over in Italy. You do not need high performance parts on a daily driver.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
Is Prestone Anti-Freeze OK? ElPaso2007 JK Wrangler Technical Forum 22 01-08-2014 04:27 PM
4.0 Water Pump Pulley Seized onto water pump grAmit TJ Wrangler Technical Forum 9 09-09-2009 04:17 PM
Prestone Anti-Freeze? man0ica TJ Wrangler Technical Forum 6 10-29-2006 12:53 PM
1st jeep! what tools? 2.5L water pump install Minnesota YJ Wrangler Technical Forum 1 09-02-2004 09:22 AM
Tranny swallowed water. Best flush method? Aggravator YJ Wrangler Technical Forum 3 07-19-2004 05:38 PM
