Water puddles in my floorboards - JeepForum.com
post #1 of 9 Old 02-23-2010, 09:04 PM Thread Starter
yjjeepn92
Everytime I get a good rain and my Jeep sits outside, ill either have a puddle in my floorboards when I open my door, or when I take the first turn in it water pours out from the heat vents all over my feet or my passengers feet. I know there is a drain tube somewhere around the air vent but im not sure where. Also i have a vent scoop with the opening facing the windsheild so im kinda curious as to how the water is getting into my air vent unless it is leaking around it. Any idears?
Jeeps are like herpes, they may act up from time to time, but you'll never get rid of em!
yjjeepn92 is offline
post #2 of 9 Old 02-23-2010, 09:14 PM
ZillaKing
My 1993 YJ does the exact same thing.
ZillaKing is offline
post #3 of 9 Old 02-23-2010, 09:30 PM
burnout189
under the hood on the firewall on the pass. side there is a big funny looking tube that comes out and down. the bottom will look like it is "pinched off" remove, clean, replace
BARNHART'S AUTO REPAIR
burnout189 is offline
post #4 of 9 Old 02-23-2010, 09:37 PM
Jeffro06
Jeffro06's Avatar
My vent tube is clear, but I still get water on my driver side floorboard after it rains, or when the snow melts off of it. I find that the rain runs in along my half door uppers, down the door and drips onto the floor. The passenger side stays dry, and I'm pretty sure it's because the road crest of the road causes the jeep to lean to the right when parked.
Jeffro06 is offline
post #5 of 9 Old 02-23-2010, 10:00 PM Thread Starter
yjjeepn92
Ill check that hose tomorrow. Thanks guys. I had full doors and a hard top so I hope that isnt the problem.
Thanks for the help.
post #6 of 9 Old 02-23-2010, 10:17 PM
H_Swank
This will help, it even has pictures!
Water on the floor, diagnostics
1991 YJ, Powered by a 97 TJ 4.0L AX-15 tranny, NP231 xfer
2005 WK, ALL Stock
"Never trade the thrills of living, for the security of existence" Live and love as if its your last day!!
Life is no fun unless, you take the path with the most resistance. -ME-
H_Swank is offline
post #7 of 9 Old 02-23-2010, 11:12 PM
DiabloYJ
While its removed, cut the pinch point off so that the crud doesn't build up there and you will never experience a problem with that again.
Agreed on the other points though that if that doesn't solve your problem the water is coming from somewhere else.
"When Life starts to pass you by..............Downshift"
Then again that used to be my motto until I got the Jeep, now that doesn't even work half of the time.
GD Thread HIJACKERS Member #1
ΜΟΛΩΝ ΛΑΒΕ
-Justin
Originally Posted by 2006Sport View Post
Sometimes I wish I had leaf springs.
DiabloYJ is offline
post #8 of 9 Old 02-24-2010, 06:59 AM
Fernando
Fernando's Avatar
1987 YJ Wrangler
I do not mean to discourage you my friend but I got tired of trying to find the leaks on my Jeep, I just removed the floor plugs and Rhino lined the tub and roll cage, water still comes in but now I don't care.
I really tried everything, changed the cowl seal, all gaskets, covered all body joints with RTV... water still made it through, It is better IMHO to just go for rust protection and let the leaks be.
Originally Posted by JeepHammer
I don't mind writing for Fernando because he reads, and re-reads EVERY WORD!... Good to write for someone that actually READS the answer, and takes time to UNDERSTAND what comes back for an answer!
Fernando is offline
post #9 of 9 Old 02-24-2010, 03:35 PM
ZillaKing
Awesome!!! Thanks for the link this will help me out too!!!
water in the jeep after going through puddles?? Dan9 TJ Wrangler Technical Forum 9 08-11-2009 10:55 PM
Puddles in my Jeep dan_yoyo YJ Wrangler Technical Forum 5 07-01-2009 08:58 PM
Puddles in floor Gamecock4me JK Wrangler Technical Forum 4 06-22-2008 01:18 PM
Puddles on my floor ballallday89 TJ Wrangler Technical Forum 7 06-01-2008 07:42 PM
So I went through some big puddles... 04WranglerX TJ Wrangler Technical Forum 4 11-04-2007 12:26 PM
