Water on passenger floor board? - JeepForum.com
post #1 of 6 Old 11-24-2011, 03:58 PM Thread Starter
baritone_mike
Why do I have water pouring inside my Jeep when it rains? - That is a fairly common occurance. The grill on the top of your engine area (just in front of the windshield) allows fresh air into the Jeep for the heater. It also allows water and snow to collect. There is a drain-hose on the firewall about 1.75" in diameter that can get plugged. Pull off the hose, and tip it upside down. Wash it out with the garden hose in the backyard and then wash the grill-area down as well pouring as much water down as possible to wash all the trapped dirt out. Place the hose back in place and enjoy dry feet again.
I read that in the FAQ so I took a butter bowl and filled it with water and dumped it into the cowl vent, all of it came out of the bottom of the Jeep and there was no water on the floor board.
After heavy rains, there is about an inch of water on my passenger floor board. There is a little stream from the front right corner of the tub, this is just judging by the wet spots on the floor.
I was wondering where else could water be getting in? My top does not leak, and the cowl vent drains. I am rhino lined and have no carpet so it is not a huge deal, but would like to get rid of the inch water on my floor.
Also looking for the cowl vent tube, I found an elbow under my battery, it is maybe a 1/4 inch rubber hose that has nothing on the end of it and goes into the fire wall. What is this? When I dumped water into the cowl vent nothing came out of this hose.
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
baritone_mike is offline
post #2 of 6 Old 11-24-2011, 04:32 PM
jsawduste
2006 YJ Wrangler
Well I guess you have already read this by your comments.
http://www.jeepforum.com/forum/f12/t...up-how-628941/
The elbow under the battery tray is a water drain for the heater box. It is seal against the firewall from the inside.
jsawduste is offline
post #3 of 6 Old 11-24-2011, 05:20 PM Thread Starter
baritone_mike
I had not read that, I just saw the one I posted about the cowl. I will have to check the other spots.
post #4 of 6 Old 11-24-2011, 05:25 PM
jsawduste
2006 YJ Wrangler
post #5 of 6 Old 11-25-2011, 01:09 PM Thread Starter
baritone_mike
So I think it is leaking through the body seam. Do you have to get auto body sealent or will any clear silicone caulking work? Also if it is just one spot do I need to redo the whole seam or can I just dab it on that one spot?
post #6 of 6 Old 11-25-2011, 01:27 PM
timatoe
timatoe's Avatar
I'm sure you could seal it with silicone, but any auto body supply/paint store should have body sealant and I believe it's pretty cheap and you can paint over it.
timatoe is offline
A/C leaking into passenger floor board PWillis TJ Wrangler Technical Forum 4 05-24-2010 02:51 PM
knock from the passenger floor board Crunchakah TJ Wrangler Technical Forum 2 03-21-2009 07:31 AM
Puddle on the passenger floor board. AircooledAddict TJ Wrangler Technical Forum 15 11-15-2006 08:34 PM
Water in my rear passenger floor board, any idea on the cause????? Fish TJ Wrangler Technical Forum 3 09-28-2004 08:51 PM
Water on the Passenger Floor Board rokbolt TJ Wrangler Technical Forum 12 06-07-2004 08:42 PM
