Water Leaking in under dash - JeepForum.com
post #1 of 8 Old 01-05-2012, 05:36 PM Thread Starter
nancy145
I have replaced the windshield and seal and the cowl and still have water leaking on passenger side. It seems to come in near the speaker and has blown the right speaker out. Any ideas of where else I can check for leaks?
Thanks!
nancy145 is offline
post #2 of 8 Old 01-05-2012, 05:47 PM
1SASjeepster
Nancy,
Sometimes the YJ develop leaks where the front of the door meets the body. Mainly this is when you have the "half doors" with the soft top on. An easy way to check it is to have a friend use a garden hose with the water on "gentle" and then go around the areas systematically. You should be able to tell where the leak is by watching for it on the inside while she/he pours the water slowly on the outside... one place at a time. I hope this helps.
Take care,
Check out "YJ V6 Conversion" if you want to see a frame up restoration of my 1992 YJ.
Check out "WWII Jeep Photos AND Restoration of..." if you want to see the original JEEP in action...
1SASjeepster is offline
post #3 of 8 Old 01-05-2012, 05:55 PM
XJNKY
my yj had a plugged drain pan. there was a rubber hose coming out of it that was stapled shut. remove the staple, massaged the tube and viola, 20 years of gunk came out and no more under dash leaks. don't know if that helps but thought I'd throw it out there. I know you said you replaced the cowl, didn't know if that was included.
XJNKY is offline
post #4 of 8 Old 01-05-2012, 05:56 PM Thread Starter
nancy145
Thanks for the tip ISAjeepster. I appreciate it! Might have to wait til spring when it warms up to bring the hose back out. It's getting cold up here. Thanks again!
nancy145 is offline
post #5 of 8 Old 01-05-2012, 06:03 PM
stroker90
I don't know what your paint/body condition is like but my floor boards would be wet after it would rain. I thought it was the windshield seal at the hinges where it can be folded down. I replaced that with no luck. Next I looked at the air intake for the heating and took all that apart to look for cracks that would allow water to get into the cab. No luck there either. I then looked at where the body/hood area meets the vertical part of the windshield. Mine had the paint from that area chipping away and it looks like there used to be seam sealer there at one point. I know this isn't the right way to do this but im planning on stripping the body down for paint in a year anyways but I took liquid seam sealer for a tent and applied that using a brush to the seam. I haven't had water on my floor boards since..
stroker90 is offline
post #6 of 8 Old 01-05-2012, 06:31 PM
1SASjeepster
Nancy,
I hope you find it when the weather warms up. I know it always embarrassed me to have that side of the jeep leak on passenger's shoes.
Take care,
post #7 of 8 Old 01-05-2012, 06:40 PM
jay-h
When you say cowl seal, what are you talking about? Did you reseal that entire seam that is in front of the windshield but behind the hood? What about the windshield wiper opening?
jay-h is offline
post #8 of 8 Old 01-05-2012, 06:52 PM
chris447
Just take the hose off, mine fell off in driveway, it was packed with gunk.... or take off the covor and pusg it oit with screw driver
chris447 is offline
Water (rain) Leaking under dash mbecnel YJ Wrangler Technical Forum 6 06-03-2010 09:13 AM
Leaking Water JeepWrangler05 TJ Wrangler Technical Forum 2 07-07-2009 11:54 AM
A/C leaking Water jh9821 TJ Wrangler Technical Forum 8 06-18-2008 05:16 PM
Water leaking into dash. Where should I look first. gary1 YJ Wrangler Technical Forum 6 09-15-2006 05:33 PM
YJ Leaking Water under dash zzbellazz YJ Wrangler Technical Forum 1 11-07-2005 07:48 AM
