Water leak on front of engine .... - Page 2 - JeepForum.com
post #16 of 25 Old 08-12-2013, 10:13 PM Thread Starter
JohnW63
Just to keep updating the thread....
I put a bit of household oil, like 3 in 1 or Super Oil on the threads and kept working the pipe in and out. It went a little further each time. When I was pretty sure it would get were I needed, I put RTV on it and got it around where it should be. Thanks for giving me the info to go forward and try.
Next, put it all together and see if I have fixed the leak.
Oh... question on the water pump gasket. The Jeep manual says to install dry. The instructions with the pump say to use RTV like product. Which way is best ?
JohnW63 is offline
post #17 of 25 Old 08-12-2013, 10:16 PM
bigbossd1030
Good to hear. And I use rtv as per the directions. And I have never had a leak after the install.
Sent from my iPhone, probably because I am bored at work.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #18 of 25 Old 08-15-2013, 03:09 PM
XJ93
The other thing you need to do is let the rtv set for a bit before you go pouring coolant into the system. Make sure to use BLUE rtv as it really is the only water resistant rtv.
XJ93 is offline
post #19 of 25 Old 08-16-2013, 06:02 PM Thread Starter
JohnW63
Yep, it's blue, and it's been setting simply because I haven't made time to put the radiator back in. I'll do that tomorrow. That's what weekends are for.
JohnW63 is offline
post #20 of 25 Old 09-12-2013, 01:06 AM
predawn
How much rtv should you use on the threads? Putting in a new water pump and have to swap the old tube over as well.
predawn is offline
post #21 of 25 Old 09-12-2013, 07:46 AM
bigbossd1030
Aren't they blind holes?
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #22 of 25 Old 09-12-2013, 06:33 PM Thread Starter
JohnW63
I'm not sure of the term " blind holes ", but mine all went together fine, with no leaks. Thanks for the help, guys.
JohnW63 is offline
post #23 of 25 Old 09-12-2013, 06:36 PM
bigbossd1030
Sorry, blind hole as in it doesn't go straight through. It stops before the bolt goes into the coolant passage. I don't think rtv on the bolts will do anything. At least I can't recall if I ever put it on the bolts.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #24 of 25 Old 09-13-2013, 09:25 PM Thread Starter
JohnW63
Nope. The hole goes right into the impeller area. I just used enough to lightly coat the threads. Much of it stayed at the top as the pipe threaded in.
JohnW63 is offline
post #25 of 25 Old 09-13-2013, 09:37 PM
bigbossd1030
Ah see,
That I couldn't remember. Wasn't sure if the threaded holes could leak.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
