Water leak on front of engine .... - JeepForum.com
post #1 of 25 Old 08-10-2013, 03:11 PM Thread Starter
JohnW63
I developed a leak somewhere on the front of the engine. It drips right off the lowest part, behind the harmonic balancer. It didn't look like a hose leak, since the low parts of those are on the hose. I figured that since I couldn't see the source, it must be the water pump, since it is the original one. Swapped it out, put on a new lower hose, had to get a new heater pipe to connect the water pump to the hose because mine was sort of roughed up by rust. Put it all together and before I could even fire it up, it was dripping.
I had a little of a leak at the upper hose to thermostat housing, and tightened that, but it was not much. I may have had a little weeping from the heater pipe to water pump, but I wasn't sure if that wasn't from the radiator hose. Neither was as many drips per minute as the low leak.
1) Is there a "freeze plug" behind the timing chain cover ?
A number if years, back I accidentally ran straight water in the car and rusted out a freeze plug. ( Don't forget to finish the steps when doing a Super Flush on the cooling system. )I replaced all the brass plugs on the side of the block. I am concerned if there IS a freeze plug back there, it may have rusted through.
2) Should there be Teflon tape on the threads for the pipe to water pump connection. It's snug, not super tight. I don't think I can get anther 360 degrees rotation to make it really tight. The water pump is aluminum, so I would rather not go gorilla on it.
3) Is there any other place to check for a possible leak spot ?
JohnW63 is offline
post #2 of 25 Old 08-10-2013, 04:38 PM
bigbossd1030
If I was at the farm I would be able to tell you for sure. But looking on google images It looks as though there is no other freeze plugs other than the 5 on the side. But I could be wrong. I think it has to be coming from either the pump or thermostat housing. It is possible you have a bad pump out of the box and its coming out of the weep hole. And I just rtv the threads. Don't overtighten it, you will be sorry lol.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #3 of 25 Old 08-10-2013, 05:27 PM Thread Starter
JohnW63
By the way, I forgot to mention , it is the 6 cylinder motor.
JohnW63 is offline
post #4 of 25 Old 08-10-2013, 05:28 PM
bigbossd1030
By the way, I forgot to mention , it is the 6cylinder motor.
Lol I assumed it was.
Sent from my iPhone, probably because I am bored at work.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #5 of 25 Old 08-10-2013, 08:58 PM
DirtKar
I pledge allegiance.
DirtKar's Avatar
I use a Teflon paste on threaded items. You could dust the front of the engine with some talc to help chase down the leak. If you had a bad freeze plug under your timing set you would have water in your oil and I don't believe you have one there anyway. Are you sure it's not coming from your thermostat housing?
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
post #6 of 25 Old 08-10-2013, 08:59 PM
bigbossd1030
I'm going to the farm now ill check it for you.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #7 of 25 Old 08-11-2013, 12:58 AM
bigbossd1030
There is no freeze plug on the front. There are five on the side and one on the back. So it's either your pump or housing.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #8 of 25 Old 08-11-2013, 11:56 AM Thread Starter
JohnW63
Thanks guys ! I really didn't want to take the rest off if there was nothing that COULD leak under there.
JohnW63 is offline
post #9 of 25 Old 08-11-2013, 01:36 PM Thread Starter
JohnW63
Another problem.
I have a new water pump and new pump to heater pipe. When I thread in the pipe, it stops close to where it needs to be aligned with the hose. When I give it a little turn with the wrench, it is pointed over the valve cover. I tried for 45 minutes to get it to start threading at a different spot, so it would be tight at a different angle, but no dice. I think the threads stop in the water pump before the pipe is actually seated on the outside. Is there supposed to be a washer or gasket between the two ? No amount of RTV will seal this under pressure unless it can be made tight.
JohnW63 is offline
post #10 of 25 Old 08-11-2013, 02:47 PM
bigbossd1030
Another problem.
Iirc there is an oring but I'm not sure that was a while ago I even touched that. I have one at the farm ill check and see if I can get it off to see if there is an oring in there.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #11 of 25 Old 08-11-2013, 03:22 PM Thread Starter
JohnW63
I examined the water pump threads and I looked like they did not go all the way through the hole. So, I took it back to the parts store and got another one. This looked fully threaded and the pipe seemed to go further. I got it back to the Jeep and it does go further. Now, it stops 180 degrees off. < sigh >
If there is an o-ring, it would make sense.
JohnW63 is offline
post #12 of 25 Old 08-11-2013, 07:06 PM
rocketboy
rocketboy's Avatar
I'm pretty sure they are pipe threads which should not have an o-ring to seal. If you look at the male portion (the pipe) you should see that it's tapered. That will verify they are pipe threads. If you use Teflon tape you'll get a good seal plus the tape is slippery and you should be able to thread it farther.
___________________
1989 YJ - 4.0L
2001 WJ 4.0L
rocketboy is offline
post #13 of 25 Old 08-11-2013, 08:59 PM
bigbossd1030
I checked, no oring, pipe thread.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #14 of 25 Old 08-12-2013, 05:16 PM Thread Starter
JohnW63
So, if it's pipe thread, I should be able to lube it to work it further around and seat it ? Teflon tape may allow it to go further by being slippery ? Given the pump is aluminum, I didn't want to risk cranking it around with a big wrench.
JohnW63 is offline
post #15 of 25 Old 08-12-2013, 05:31 PM
bigbossd1030
I turned in with a wrench till it lined up. I used rtv to seal it. Seeing as how it is pipe thread. The rtv will seal properly as the treads are tapered an it tightens as it goes in. There is a possibility of cracking it, but I believe they have the threads started in a strategic matter as to allow it to line up without cracking.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
