water in the jeep? - JeepForum.com
post #1 of 5 Old 06-21-2010, 02:41 PM Thread Starter
coopstain
water in the jeep?
does anyone else get about 2-3 inches of water in there jeep with the top on after a big storm cause it happens every time it rains and idk where it would come from
"Tilt your knee slightly out the door, its like Ram Air for your goods." - Flatlander
coopstain is offline
post #2 of 5 Old 06-21-2010, 02:48 PM
Louie4
Probably from the windshield. Check this out:
http://www.jeepforum.com/forum/f12/t...up-how-628941/
It will get you started. I ended up drilling a hole on each side of my windshield frame to let the water drain.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #3 of 5 Old 06-21-2010, 03:03 PM
pasinbuy
That is a good write up by Rusty although I disagree about cutting a inch off of the hose on the firewall.
Just clean it and watch it. If you cut it you may have motor odor and fumes coming into your cab. The cowl drain is the first place to look for your leak.
pasinbuy is offline
post #4 of 5 Old 06-21-2010, 05:11 PM
1998zj
Pull the floor plugs and you wont get 2-3" of water.
"Our lady of blessed acceleration don't fail me now"
1998zj is offline
post #5 of 5 Old 06-21-2010, 07:44 PM
Nokinja
Take my advice and find the source of the water or else risk your Jeep to the angry gods of rust and tetanus.
Nokinja is offline
Going through water in my Jeep? RedHotChiliDog TJ Wrangler Technical Forum 20 07-21-2010 06:43 PM
Water in the Jeep Grinner JK Wrangler Technical Forum 1 06-06-2010 11:46 AM
jeep in water.... and now water in tranny. doofusismynane TJ Wrangler Technical Forum 6 10-29-2009 06:02 PM
water getting in my jeep deryk111 TJ Wrangler Technical Forum 4 12-03-2008 04:20 PM
Run your Jeep on water! Fargo TJ Wrangler Technical Forum 25 05-31-2008 09:05 AM
