Water getting in yj need help finding solution - JeepForum.com
 2Likes
  • 1 Post By bruinjeeper
  • 1 Post By timatoe
post #1 of 13 Old 12-17-2016, 01:56 PM Thread Starter
Bubseth
Hey guys my 1990 yj has a hard top and full doors on it and every time it rain sleets or snows It leaks through somewhere and ends up on both the driver and passenger floor. It is most heavy in the center of the floor pans and hugs the indent in the floor for the tranny. It just sleeted and I took pictures to show you where it's landing. Any help or suggestions on where it's coming from and how to seal it up would be appreciated
Bubseth is offline
post #2 of 13 Old 12-17-2016, 01:58 PM Thread Starter
Bubseth
Passenger side
Bubseth is offline
post #3 of 13 Old 12-17-2016, 02:29 PM
14Sport
Proud Deplorable
14Sport's Avatar
First thing I would try because it's free is check to make sure your cowl drain is clean and not clogged.
Here's what it looks like. It has a purple line drawn on it in the pic...
http://www.jeepforum.com/forum/f12/w.../#post14392416
If not that I'm leaning toward the seal under the windshield.
My observations are based on my experiences...YMMV.
14Sport is offline
post #4 of 13 Old 12-17-2016, 04:53 PM
Louie4
Is that snow on the floor board?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #5 of 13 Old 12-17-2016, 06:43 PM
timatoe
timatoe's Avatar
If that's sleet that has come from the outside into the inside, it should be quite obvious where it's coming from, it has to be a big gap.
Look at this thread here in the Frequently Asked Questions.
timatoe is offline
post #6 of 13 Old 12-18-2016, 10:14 AM Thread Starter
Bubseth
It comes from under the dash because when it rains it drops on my leg
Bubseth is offline
post #7 of 13 Old 12-18-2016, 11:32 AM
14Sport
Proud Deplorable
14Sport's Avatar
Clean the drain tube in the engine compartment. Mine did the same thing when I first bought it. Mostly when I was turning.
14Sport is offline
post #8 of 13 Old 12-20-2016, 11:20 AM
bruinjeeper
bruinjeeper's Avatar
no easy way around this if the above suggestion yields no result.
you have the jeep in front of you... take out the dash... look around
Kuntryboy816 likes this.
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
~YJOTM MAY '16~
bruinjeeper is offline
post #9 of 13 Old 12-21-2016, 06:00 PM Thread Starter
Bubseth
I checked the cowl drain and it wasn't clogged but I realized the windshield washer sprayers were off of the cowl I found them in the dash and hooked them back up to the hoses and tightened them down. Could the water and sleet been coming from the holes the sprayers sit in?
Bubseth is offline
post #10 of 13 Old 12-21-2016, 07:08 PM
NHfireLJ
NHfireLJ's Avatar
Doubt that much sleet came thru the holes.. check the vent tube flapper doors for the outside air to cabin vent
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #11 of 13 Old 12-21-2016, 07:46 PM
dancytron
Look at the firewall from the engine side. In particular, look where the big bundle of wires from the ECM come through the firewall. If the ECM has been bypassed (if you have a 4.2), there might just be a big hole there. Water came through mine until I plugged it up. Otherwise, the big rubber grommet might be loose or rotted or something. Look at the other places stuff goes through the firewall.
Fill out your profile so we know what kind of jeep you have.
dancytron is offline
post #12 of 13 Old 12-22-2016, 02:02 AM
timatoe
timatoe's Avatar
Did you do this?
Originally Posted by timatoe View Post
....Look at this thread here in the Frequently Asked Questions.
14Sport likes this.
timatoe is offline
post #13 of 13 Old 12-22-2016, 07:00 AM
Kuntryboy816
Kuntryboy816's Avatar
Could've sworn that I posted this response yesterday.... well, anyways
Pray you don't find this!! Have you checked to see if your top is sealing tight to the windshield frame?
Originally Posted by 14Sport View Post
Until you know exactly what is underneath the, well, not really sure what to call them...mistakes...it's hard to come up with a plan of action.
Kuntryboy816 is offline
