Water coming in around glovebox - JeepForum.com
post #1 of 13 Old 07-09-2013, 11:24 AM Thread Starter
Wrangler11
Wrangler11's Avatar
I'm driving in a bad rain storm and I noticed water dripping on the sides of the glovebox. I opened the glovebox and its dry inside. Any ideas?
2002 Grand Cherokee Limited
1994 Toyota Land Cruiser (camping offload toy)
Wrangler11 is offline
post #2 of 13 Old 07-09-2013, 11:40 AM
NHfireLJ
NHfireLJ's Avatar
windshield seal (where the windshield folds down) ... ?
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #3 of 13 Old 07-09-2013, 11:53 AM Thread Starter
Wrangler11
Wrangler11's Avatar
Is that a common thing?
post #4 of 13 Old 07-09-2013, 12:49 PM
DpDave
Yes it is... Just need a need rubber gasket.
If yer gonna fight, fight like the third monkey on the ramp to Noah's Ark.
My Build Thread:
DpDave is offline
post #5 of 13 Old 07-09-2013, 01:43 PM
jaycal3
I agree, its most likely the cowl seal. I have purchased a replacement and have yet to install it. I am leaking under the dash... fun times...Not!
93 YJ, 6 cyl,3.5" BDS,1" Prothane BL,1/2" booms, 33" Mickey Thompson MTZ on MT Beadlocks.
Do your part for Leukemia research - help find a cure.
KCCO
jaycal3 is offline
post #6 of 13 Old 07-09-2013, 03:13 PM
GrantYJ
I agree with the above comments about the cowl/windshield seal. If yours has never been changed that's probably the culprit (and it's a bugger to get the windshield back into place with the new gasket).
It's probably worth it to make sure your cowl is draining properly as well. Pour a pitcher of water into the cowl vent (grate looking doo-dad between the hood and windshield). If water doesn't immediately start pouring out under the Jeep at the firewall toward the passenger side, your drain tube may be clogged.
If it's the cowl/windshield gasket, after you get it screwed to the bottom of the windshield and you're ready to fold the windshield back into place, spray it liberally (very liberally) with silicone spray. That will help. It would also be a good idea to have a couple of helpers. The two strongest on either side pulling the windshield back and the third person to put the countersunk torx bolts through the spreader bars to the windshield frame.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.” ― Robert M. Pirsig, Zen And The Art Of Motorcycle Maintenance: An Inquiry Into Values
GrantYJ is offline
post #7 of 13 Old 07-10-2013, 12:17 AM
legato
i can't stand that **** either! my socks and shoes are always wet when it rains.
If I were an ARB in a Dana 35, I would kill myself too.
legato is offline
post #8 of 13 Old 07-10-2013, 07:34 AM
UZI4U
Replace the cowl gasket. Rock Auto has the best price on them. When you do replace it, take the opportunity to drive around with the windshield folded down. I do it now at least once every week or so.
MCLMM
UZI4U is offline
post #9 of 13 Old 07-10-2013, 08:26 AM
crackedcornish
I got one from Quadratec and the lip that is supposed to lay flat against the face of the windshield frame is curled...does the one from Rock Auto lay flat like the OEM gasket did or is it curled too?
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
post #10 of 13 Old 07-10-2013, 10:14 AM Thread Starter
Wrangler11
Wrangler11's Avatar
If the windshield seal is the problem I will probably wait. I need to replace the windshield frame and glass.
post #11 of 13 Old 07-10-2013, 10:28 AM
jay-h
http://www.jeepforum.com/forum/f176/...water-1544977/
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #12 of 13 Old 07-10-2013, 10:29 AM
crackedcornish
don't wait too long to fix the leak or you'll be replacing/repairing the dash as well...it's not really painted, except for the areas out by the ends that show, and it rusts out rather quickly
post #13 of 13 Old 07-10-2013, 04:56 PM
UZI4U
I ordered two and they both were flat and an easy install...one on mine and one on a buddy's.
MCLMM
UZI4U is offline
