Warrior Tube flares - Page 2 - JeepForum.com
post #16 of 20 Old 11-23-2011, 10:30 PM
jeepnbrett
I was seriously considering the warrior tube flares. Then I got to thinking.... I can make something like that.
It wasn't that hard to do. The bends were done with cheepo HF bender that everyone says doesn't work and I welded them with a cheepo HF 90 amp flux welder. I have since bought a better welder but the cheap tools did what I asked of them and I am happy with what I ended up with.
Brett
4.0, AT, 3.5 Fabtech, 1" SRS, 1" BL, 35x13.50x15 Toyo MT's, HP30, TJ shafts, Lockrite, 8.8, Power Trax No Slip, 4.11's, Warn bumpers, W8274, SYE, and a bunch of other stuff....
jeepnbrett is offline
post #17 of 20 Old 11-24-2011, 07:02 AM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Not Bad!!!
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #18 of 20 Old 11-24-2011, 10:00 AM
jeepster93
jeepster93's Avatar
Originally Posted by edmonddantes View Post
Terrible idea. Strengthening a flare that is attached to your factory "weak" sheet metal effectively doubles the width of your fenders...I for one have never been on the trail and thought; "you know what I need? My sheet metal fenders to be 4" wider"
These are one of my most hated products. At least plastic flares give. These are the worst of both worlds.
+1
You hit a tree with these flairs and you will damage the fender the flair is attached to.
The flair needs to be attached to a piece of armor, plain and simple. Front and rear.
Or.
The flair needs to give, and transfer no energy to the fender.
Tube flairs should stop body damage, not cause it.
jeepster93 is offline
post #19 of 20 Old 11-24-2011, 10:25 AM
twiisted71
This is true in most instances. I however will be needing a set for tire coverage not trail damage protection.
twiisted71 is offline
post #20 of 20 Old 11-24-2011, 11:13 AM Thread Starter
NHfireLJ
NHfireLJ's Avatar
+1
Or.
If you saw my jeep, It really doesn't matter...BONDO!!!
SOLD
YJOTM FEB 2013
NHfireLJ is offline
Currie vs warrior tube doors woo Wrangler General Discussion 12 07-24-2011 04:02 PM
warrior tube flares vs bushwacker flats rvd502002 JK Wrangler Technical Forum 2 04-29-2011 01:49 PM
warrior product tube fenders? Jodyblip JK Wrangler Technical Forum 6 10-27-2009 02:34 PM
Warrior metal tube fender flares all3forus TJ Wrangler Technical Forum 0 05-14-2009 08:29 PM
warrior tube fender flares schu TJ Wrangler Technical Forum 4 05-11-2009 10:24 PM
