Wanting a street performance jeep as well - Page 2 - JeepForum.com
post #16 of 17 Old 08-14-2011, 12:47 PM
Dryseals
1980 CJ7
Originally Posted by Galligher View Post
That rocks! I don't think I will get it that fast any time soon. With autos,anyone run a smaller stall for the converter but bigger than stock? Was thinking around 2000rpm if I run an auto vs manual.
Why? Higher stall is going to ruin any drivablity for off road use or in the snow, stick with the stock. The only time you want a higher stall is if the motor requires it. So unless your adding some kind of lumpy cam, stick with stock.
The more you try to get out of the engine, the more things you'll need to make it work right. Think about headers, once you start shifting the torque curve upwards, you need better exhaust flow, your jeep is not exactly made for it unless you start hanging things out of the bottom.
You'll add more complications in the build and may not see the results. Build your engine to fit your vehicle, not the other way around. A stock 350 will have more than enough power to sit you in the seat tight. In fact, if it was me, I'd be looking to shift the torque to be higher in the lower RPMs. You'll still have plenty of motor for the street.
Dryseals is offline
post #17 of 17 Old 08-14-2011, 07:26 PM Thread Starter
Galligher
Yep, I understand the whole cam LSA/lift/duration- carb single plane/dual plane - fuel injection long runner/short runner effects on running a stall with a torque converter. I have had turbo cars that the stall did a good job of building boost with the brake on! In looking specifically at the 5.0 or 5.3LS, they both really need a cam/spring swap as junkyard engine pulls. I have much more experience with the 5.0 and know many gt-40P builds with good results with the A231 or Crane 2031 (forget the exact number?) cam and long tubes for good all around power/torque.
In building the entire package, I need to know about driving a 4wd vehicle with a stall. I have zero experince with 4wd vehicles. I would think driving a high stall converter would be a pain off-road. But I would like to have a little bit of a stall to get a little extra kick on the road. Again, on the street a 2200rpm stall is pretty mild if it is a good/efficient converter. But a stall off-road (even though I will only maybe be 5% offroad) may be a big no-no. I don't know. If that is the case, I will probably really consider the manual. I really like the Wrangler, I just want to REALLY smoke the 18 year old in the stock eclipse with the "fart can" on the back to the next light...
Galligher is offline
chevy , ford , performance , swap
Hawk Performance HPS High Performance Street Disc Brake Pads? NW Jeep TJ Wrangler Technical Forum 54 11-02-2011 10:54 PM
08 jk wrangler, wanting better headlight performance elegal73 JK Wrangler Technical Forum 43 11-14-2009 03:03 PM
Transmission / Gearing for street performance greaneyk TJ Wrangler Technical Forum 2 09-04-2006 12:21 PM
Mud Terrain Street performance elmo510 TJ Wrangler Technical Forum 19 07-12-2004 09:56 PM
2" lift question...street performance SSJeep YJ Wrangler Technical Forum 4 05-07-2001 05:27 PM
