Want to pull a trailer..... - Page 2 - JeepForum.com
post #16 of 31 Old 04-03-2013, 02:58 AM
kgb_m3
Originally Posted by CBinDC View Post
What are the best gears if you're running 31s w/ 4.2L?
Good question, I would like to know as well but my 4.2 is auto..
89 YJ 4.2L
96 XJ 4.0L
http://www.jeepsunclassified.com
kgb_m3 is offline
post #17 of 31 Old 04-03-2013, 04:09 AM
roadyrob
1987 YJ Wrangler
http://www.google.com/imgres?imgurl=...9QEwBQ&dur=785
heres a gear-tire chart where you can look up RPM's, I'm going with 3.73 gears with 31" tires. the 4.2 likes low RPM's so you don't want to gear it to low.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #18 of 31 Old 04-03-2013, 07:49 AM
zeus87gn
1987 YJ Wrangler
3.55
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
post #19 of 31 Old 04-03-2013, 08:05 AM
flea1987
Originally Posted by zeus87gn View Post
3.55
Nice chart post! this will help me with my gears when the time comes
flea1987 is offline
post #20 of 31 Old 04-03-2013, 08:08 AM Thread Starter
CBinDC
3.55
Is that for manual or auto? Or does it not really matter?
CBinDC is offline
post #21 of 31 Old 04-03-2013, 08:27 AM
flea1987
It's based solely off tire size
flea1987 is offline
post #22 of 31 Old 04-03-2013, 09:00 AM
skyj
I sold my truck so I could have the jeep. I got out of construction and didn't need my truck anymore, but like you still hall stuff to the dump. I had 3.07 gears 33's and 5 speed manual it sucked, but I was only doing it once and a while so I didn't care. Now I have 4.56 gears 35's and I use my jeep for small little construction jobs I pick up from a realtor friend. Just last week I loaded up all my tools and some material and headed 20 miles out of town to go do some repairs on a house. It pulled great at 65. Just like everyone has said just allow,yourself more time to stop. I also built me a nice bumper with a hitch and it ties into the frame in 6 places, if you bolt directly to the flimsy back channel it will eventually rip it off. Then you will have a projectile, so make sure you can tow properly too.
and at least every other weekend in the summer its towing my dirt bike to the hills.
build thread:
skyj is offline
post #23 of 31 Old 04-03-2013, 09:08 AM Thread Starter
CBinDC
How does the bumper tie in, did you weld the bumper to the frame? Thanks for chiming in.
CBinDC is offline
post #24 of 31 Old 04-03-2013, 09:42 AM
GrantYJ
If you're only occasionally pulling a small trailer, I wouldn't mess with a regear. I have a 2.5 on 33s and while it's not a lot of fun, I can pull a small trailer but I avoid it like the plague. Like everybody else has said, leave plenty of room for braking and wait for a nice big hole before pulling into traffic.
The main reason that I avoid it is due to the short wheelbase rather than the lack of power and brakes. Pay attention to how you load your trailer or the trailer will decide where the back of your Jeep goes.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.” ― Robert M. Pirsig, Zen And The Art Of Motorcycle Maintenance: An Inquiry Into Values
GrantYJ is offline
post #25 of 31 Old 04-03-2013, 10:28 AM
zeus87gn
1987 YJ Wrangler
My experience with a manual
Not for sure on the auto
More experience will chime in im sure
zeus87gn is offline
post #26 of 31 Old 04-03-2013, 10:28 AM
skyj
My bumper is made ot of 2x4x3/16". I used the existing bumper mounts through the rear crossmember but made my own frame tie-in brackets and welded them to the frame. Then on top of the rear frame, I welded brackets that extend out and over the top of the bumper, it bolts to the bumper there. Then on the bottom of the bumper, I welded brackets that extend to under the frame and bolt to the bottom of frame. I can easily unbolt my bumper and run without it if I want to only takes a few minutes to unbolt it all. I can get pics here in a few minutes if you want?
build thread:
skyj is offline
post #27 of 31 Old 04-03-2013, 10:51 AM
skyj
Her is a shot of the whole bumper. I built the swing away portion pretty much following besrk bumper build in fab shop, but got a little creative with my latch handle.
Here is the tie-in on the top of the bumper.
Here is the bottom frame tie-in.
build thread:
skyj is offline
post #28 of 31 Old 04-03-2013, 11:16 AM
Beachcruiser
1987 YJ Wrangler
As far as towing, I'd concur w/ the majority here. Braking is where you need to be VERY careful...especially in the rain/curves/etc.
Having said that, I've towed a boat & a small utility trailer loaded w/ motorcycles (separately, of course) on 500+ mile highway trips w/ zero problems.
Then again, Grannies were passing me with the middle finger salute.
probably out breaking stuff.
Beachcruiser is offline
post #29 of 31 Old 04-03-2013, 11:21 AM
flea1987
Get this by driving a 2.5L towing nothing as well
flea1987 is offline
post #30 of 31 Old 04-03-2013, 02:10 PM Thread Starter
CBinDC
Skyj thanks for the pics. That's really helpful. Now all I have to do is buy a welder and learn how to use it. Let the emptying of my pockets begin [again]!
CBinDC is offline
