want to change my intrior color - JeepForum.com
post #1 of 8 Old 06-17-2002, 10:29 AM Thread Starter
bonehead99
bonehead99's Avatar
I found some stuff that you can spray on leather, vinyl, and other materials. Has anyone used such a product? I want to go to black, I'm not sure if the stuff will work on the doors, parts of the dash and the center-console. Thanks for the info!
94 YJ 4.0 HO 3sp Auto, 3" RC Lift, 1" Shackles, 3" BL, 31x10.50, Pacesetter Armor-Coated Header, Homemade Air Intake w/ K&N
bonehead99 is offline
post #2 of 8 Old 06-17-2002, 10:54 AM
evilpsych
evilpsych's Avatar
if you're talking about that vinyl/leather dye, then it's an ok product, depending on what color you want to make it. I havent seen it work going from a dark to a light color, so be careful. If you've got a tan interior and want to go to a gray, it should work pretty darn good.
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #3 of 8 Old 06-17-2002, 11:25 AM Thread Starter
bonehead99
bonehead99's Avatar
will it work on the center-console and other interior plastics?
post #4 of 8 Old 06-17-2002, 12:44 PM
St.LJustin
St.LJustin's Avatar
For the plastics and vinyl, you can buy paint in a can, usually from Autozone for those surfaces. It would probably be pretty easy painting everything black. I'm sure it would look great too but it would definitly show scratches and that black vinyl would be dangerously hot from a sunny day. (Keep some towels to sit on until they cool down maybe? <img src="http://www.stopstart.fsnet.co.uk/smilie/huh.gif" alt="" />)
Black 95 4.0 YJ, RE Extreme Duty 4.5" with 33x12.5 BFG MTs and Much Much More
Member #5 of the Black Jeep Club
St.LJustin is offline
post #5 of 8 Old 06-17-2002, 10:00 PM
AllanAlxndr
There is some stuff called Flexible Coating and I believe it is made by SEM. I was thinking of using this on my Hardtop. It comes in a variety or colors and dries instantly...
Allan
***What do I know, I just cause Problems***
*'90 Wrangler*
*4 Banger*
*6" of lift, (4" suspension, 2" body)*
*33" ATs on Outlaw II's*
*Pioneer DEH3500/CD deck*
*1800WATT Amp w/ Custom Box*
*2 - 8" Rockford Fosgate HEs*
*Cobra 18WXSTII w/ 4' Firestik Antenna*
Member of
AllanAlxndr is offline
post #6 of 8 Old 06-18-2002, 04:24 AM Thread Starter
bonehead99
bonehead99's Avatar
thanks for everyones help! I was hoping to not spray paint the plastics, i'm afraid it will crack or peel after awhile. Anyone know to remove the upper dash?
post #7 of 8 Old 06-18-2002, 08:25 AM
AllanAlxndr
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by bonehead99:
<strong>thanks for everyones help! I was hoping to not spray paint the plastics, i'm afraid it will crack or peel after awhile. Anyone know to remove the upper dash?</strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">With that Flexible Coating, I don't thing you will have to worry about that...
<a href="http://www.worlduph.com/semdye.htm" target="_blank">http://www.worlduph.com/semdye.htm</a>
Allan
*'90 Wrangler*
*4 Banger*
Member of
post #8 of 8 Old 06-18-2002, 09:32 AM Thread Starter
bonehead99
bonehead99's Avatar
Thanks for the website...it helped alot. Now I just need to figure out how much I need.
So what if one would want to change the color of their soft topů. JayTaylor.WV TJ Wrangler Technical Forum 15 10-11-2007 08:50 PM
Interior color change elton YJ Wrangler Technical Forum 7 06-09-2007 05:19 AM
change interior color? Red Menace TJ Wrangler Technical Forum 5 04-02-2006 05:45 PM
Color Change fatterson71 YJ Wrangler Technical Forum 17 04-28-2003 06:40 PM
Want to change interior color bonehead99 YJ Wrangler Technical Forum 0 06-07-2002 01:02 PM
