Walker front exhaust pipe is only 2" diameter??? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Walker front exhaust pipe is only 2" diameter???
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNew jk doors from steinjagerEliminate Hood Flutter!!!
Unread 06-05-2014, 03:03 PM   #1
1984Laredo
I'm doing a 4.0 swap in my CJ7 and ordered a Walker replacement downpipe for '93-95 YJ with a 4.0L (part number 53475). All the specs I read for the pipe list it as a 2.25" pipe. All I've read about the YJ and other Jeeps with the 4.0 says that these came stock with a 2.25" pipe.
So, I get the Walker 53475 in yesterday, and, much to my surprise, it's a 2" pipe that is flared to 2.25" at the end to accept another 2" pipe slid into it....
Can anyone confirm that the downpipe on a 4.0 YJ is supposed to be 2.25" diameter all the way down and not just at the flare on the end?
1984 CJ7 Laredo
4.0 I-6 / T5 / D300 / D30 / D44
Black Diamond 3" lift, 33" tires, 4.11 gears
1984Laredo is offline   Reply With Quote
Unread 06-05-2014, 09:38 PM   #2
plym49
I wouldn't sweat it unless you drag race your Jeep.
Smaller diameter means higher velocity means better low-rpm scavenging means more low-end torque.
Smaller diameter will hurt the top end as the engine tries to push more gas through the pipe than it can flow.
You will never hit that point with your motor.
plym49 is offline   Reply With Quote
Unread 06-06-2014, 09:24 AM   #3
StanF
Personally, I like using the TJ downpipe on the YJ. It wraps around in front of the oil pan for better clearance. You might want to consider it.
My Ammo Can Console: http://www.jeepforum.com/forum/f12/yet-another-ammo-can-project-finished-1498520/
My 8.8 Swap: http://www.jeepforum.com/forum/f12/yet-another-ford-8-8-swap-extras-1565339/
StanF is offline   Reply With Quote
Unread 06-06-2014, 09:41 AM   #4
Mobile_Homie
Desert Rat
Mobile_Homie's Avatar
Just did this on my Jeep. Love it.
Mark
Smoke em if you got em!
Click here
Mobile_Homie is offline   Reply With Quote
Unread 06-06-2014, 10:18 AM   #5
1984Laredo
I can't use the TJ pipe (or even the full YJ pipe) because this is going in a CJ7. The front driveshaft is on the passenger side, so the exhaust has to be routed straight down the driver's side frame. My intent was to buy this YJ pipe and cut it just after the first bend (where its pointing straight back) and connecting my pipe there.
So are the factory YJ down pipes 2" OD until the end at the flare like this replacement?
1984 CJ7 Laredo
Unread 06-06-2014, 01:47 PM   #6
XJ93
Yes, 2" until the flare at the end is correct, I still have factory exhaust on my 95 and that's what mine has.
XJ93 is online now   Reply With Quote
Unread 06-06-2014, 01:55 PM   #7
1984Laredo
Ok, thanks for verifying this pipe is correct. If this is what the factory used, I'm good with it. Just wasn't under the impression that's what it used. Thanks again!
1984 CJ7 Laredo
Unread 06-06-2014, 01:56 PM   #8
1984Laredo
Just to confirm- everything from back from the cat to the tailpipe is 2.25"?
1984 CJ7 Laredo
Unread 06-06-2014, 02:04 PM   #9
XJ93
Yeah all my stuff is 2.25" and I just replaced muffler and tailpipe with o.e. replacement.
Unread 06-06-2014, 08:28 PM   #10
The_Goob
Hell on Wheels
The_Goob's Avatar
my stock 4.0 downpipe was 1 7/8" with 2 or 2.25 outlet to cat. I did the tj pipe. cat back is all 2.25
-- Hell on Wheels -- My YJ Build Thread
-April '14 YJOTM-
The_Goob is online now   Reply With Quote
