Wait time before vinyl on fresh paint? - Page 2 - JeepForum.com
post #16 of 18 Old 12-26-2013, 12:00 PM
kingcat400
So you're telling me that on a 20+year old jeep, where the paint still has at least some shine, and the original stickers are on it, that stripping that door with media blasting, smoothing the metal, applying primer, skim coats as needed, block sanding, applying a layer of modern 1 or even 2-stage paint, your 3 generations of paint professionals can't make it look as if that sticker was never there?
Or are you talking about a 20+ year old vehicle wherein the paint is basically gone around the sticker, and rust has pitted the metal around the sticker? That I can believe.
my jeep still had decent paint when body work began. when i striped the doors you could see a discoloration in the metal in the shape of the graphic.
yes filler will help the issue but areas do not always need filler where graphics were. we can make them go away but you always risk that they will come back years later but most of the time anything that comes back can be removed with a simple wetsand and rub. if i wanted my jeep to be perfect i could sand and rub it and make it go away but i will just let the trees sand it for me
i was just making a point that waiting will not stop it from printing the paint.
kingcat400 is offline
post #17 of 18 Old 12-26-2013, 12:03 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
I agree. As stated earlier:
But then again, it's a YJ...
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 33" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #18 of 18 Old 12-26-2013, 12:42 PM Thread Starter
J-Quad
why put the splash's back on? i had mine off the day i bought my jeep.
I guess it's a case of, "To each their own".
With the right decal, I like the look....it's as simple as that.
J-Quad
J-Quad is offline
