Waggy springs question - JeepForum.com
post #1 of 8 Old 12-01-2012, 12:49 AM Thread Starter
ghetdjc320
Hello, I am wanting to replace my springs with waggy 7 leaf packs on all 4 corners mainly to improve ride and gain some lift plus I can get them fairly cheap. My question is; can I mount the rear spring on regular instead of reversed so that I keep my stock rear wheelbase? I just want to stretch the front but not the rear. Thanks! Also do I have to make any steering corrections for the front stretch?
-DJC
ghetdjc320 is offline
post #2 of 8 Old 12-01-2012, 10:09 AM
YJ4LIFE
Yes. Probably not but maybe.
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline
post #3 of 8 Old 12-01-2012, 07:42 PM
skyj
Yes you can mount the rears in reverse for no stretch. The front you won't have to do anything to your steering, but your front drive shaft will be too short. It will need to be lengthened. You will benefit from slightly longer shackles to, stock ones limit movement.
build thread:
skyj is online now
post #4 of 8 Old 12-02-2012, 03:02 AM Thread Starter
ghetdjc320
Thanks for that info! I have HD warrior shackles now that are a bit longer than normal so they should work fine.
-DJC
post #5 of 8 Old 12-14-2012, 06:45 AM
VACJ5
I have wagoneer springs on all 4 corners. I have mine in the "stretched" direction. You should be fine in the front, but you are going to love the ride. They are very soft riding springs.
79 CJ5 Silver Anniversary Edition... revived & sold *sniff
91 YJ 4.0 L, with some stuff bolted to it...
91 2 door Cherocar... in progress
Custom CNC cut Jeep parts & more
VACJ5 is offline
post #6 of 8 Old 12-16-2012, 08:18 PM Thread Starter
ghetdjc320
Do you have the 7 leaf springs? If so how much lift would you say they give?
-DJC
post #7 of 8 Old 12-16-2012, 08:35 PM
rambo3489
x2 on how much lift they give.
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #8 of 8 Old 12-16-2012, 08:53 PM
skyj
7 leaf. They give about 2" SUA depending on how old and abused they were.
build thread:
skyj is online now
