Waggy Spring Lift Questions - JeepForum.com
post #1 of 6 Old 08-11-2011, 10:20 PM Thread Starter
kjg26
kjg26's Avatar
I have a 2 sets of waggy springs to lift my 93 YJ. I have a couple questions before I undertake this lift. I will be using some 5/8 in boomerang shackles with these springs. For the bushings, do I need YJ specific bushings or just new bushings for the waggy springs? Also what type of bushing would best suit this lift? This will be an occasional street driver with mostly trail use.
Next question, one set of springs appears to be newer (they're clean), the other set has surface rust and looks older. What would be best way to paint these? I don't want to hassle with undoing the springs, I was thinking sand down what i could and rustoleum spray bomb it.
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #2 of 6 Old 08-12-2011, 08:48 AM Thread Starter
kjg26
kjg26's Avatar
anyone?
kjg26 is offline
post #3 of 6 Old 08-12-2011, 10:45 AM
92 Green YJ
92 Green YJ's Avatar
You will need bushings for the waggy spring eye size. Then the correct size sleeves to go inside them. If memory serves u need 1/2" sleeves for the shackle ends and 9/16" sleeves for the frame ends. Personally I run poly bushings. They might not be quite as soft as the stock rubber, but they last a heck of a lot longer. Just be sure to grease them when installing.
As for paint, yeah u could just clear the surface rust and spray bomb them. Though it's better to tear them down and do each leaf individually.
edit:
you do know also that the Waggy springs, in addition to providing lift, can be used for stretch purposes as well correct? if you install them for stretch you will need to do some driveshaft modifications and lengthen your brake lines at the minimum
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #4 of 6 Old 08-12-2011, 11:14 AM
jeepster1407
Easy!... sell em to me. no seriously i live in Dahlonega and work in gainesville ( north of ATL) where did you get them at?
jeepster1407 is offline
post #5 of 6 Old 08-12-2011, 08:25 PM Thread Starter
kjg26
kjg26's Avatar
Jeepster clear your messages
kjg26 is offline
post #6 of 6 Old 08-12-2011, 10:38 PM
jeepster1407
I did please pm me again. Sorry!
_________
My Thread -
waggy spring question nathan2034 YJ Wrangler Technical Forum 1 01-28-2010 06:41 AM
Shopping list for a waggy spring lift. What do I need? fireshadow YJ Wrangler Technical Forum 6 12-09-2009 12:14 PM
soa w/ waggy spring jeepinMatt YJ Wrangler Technical Forum 3 12-11-2006 02:20 PM
soa waggy spring jeepinMatt YJ Wrangler Technical Forum 4 11-21-2006 08:36 AM
another waggy spring question ncjeepinyj YJ Wrangler Technical Forum 3 05-02-2006 08:31 PM
