Waggy pitman arm - JeepForum.com
post #1 of 5 Old 08-02-2011, 01:39 PM Thread Starter
Superhoob
1987 YJ Wrangler
Waggy pitman arm
I got a pitman arm from waggoneer that I read was about two inches longer that my stock YJ. It fit on my steering box, and even the drag length fit, which was all great, but it turns out to be only one inch longer, and I still have a little binding. Is there another pitman arm that will fit my steering box but be two inches longer than stock?
Superhoob is offline
post #2 of 5 Old 08-02-2011, 06:34 PM
PA_YJ19
xj's r for closer to a 4 inch lift but I'm pretty sure would work out for ya.
PA_YJ19 is offline
post #3 of 5 Old 08-02-2011, 06:44 PM Thread Starter
Superhoob
1987 YJ Wrangler
I am runnig a 4" lift, with a shackle reversal. My issues is I swapped in a D44 from a ~78 F150, and I am having a hard time with all the stearing geometries. I used the same vintage tie rod and drag length, shortened the drag length, and flipped the ball joints on the tie rod because it hit the springs in the under position.
But the XJ is longer that the YJ by 2"? If the pitman arm drops to correct for a 4" lift, then it would not work, becasue I am almost parallel as it is.
post #4 of 5 Old 08-02-2011, 11:41 PM
fratis
fratis's Avatar
i think he is confusing "drop" with overall "length." are you having a problem with reduced steering radius because your pitman is shorter then your knuckle arm?
i made my own pitman arm. my hi-steer arms are 8.5" long and this just doesnt work with a 5" pitman.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #5 of 5 Old 08-08-2011, 01:30 PM Thread Starter
Superhoob
1987 YJ Wrangler
I am not having a problem with the turning radius. The problem is the drag length come in contact with the tie rod at the ends of the steering travel. If I could get a pitman arm the was about 1 inch longer, I think this would solve the issue. It does not seem to affect steering, but I don't like the contact when I turn.
Is there an off the shelf pitman arm the will fit my YJ steering gear? I can rework the other end to accept my ball joint. Making my own might be difficult, does anyone know a shop that makes custom pitman arms?
waggy 44 HP or LP? three YJ Wrangler Technical Forum 42 07-29-2007 04:19 PM
waggy dana 44 drag link to YJ pitman arm y2kmxz YJ Wrangler Technical Forum 1 03-19-2007 06:48 PM
Waggy D44 93YJjeep YJ Wrangler Technical Forum 1 02-08-2006 07:20 PM
waggy 44, isuzu 12 bolt, waggy leaves (sua), tj flares mississippi_xj YJ Wrangler Technical Forum 6 12-08-2005 07:18 AM
drop pitman arm and pitman from XJ bighair YJ Wrangler Technical Forum 4 05-28-2002 01:10 PM
