Waggy 44s+SOA= steering questions?? - JeepForum.com
post #1 of 13 Old 11-03-2013, 11:32 AM Thread Starter
jamnjeep
I am considering picking up a pair of 1990 Waggy 44s and going SOA with RE 1.5 SOA springs. Addressing the steering is my biggest concern. I have searched and read numerous build threads but still unclear of the simplest way to correct the steering. I am fine with leaving the tie rod under the springs. But what is needed to run the drag link on top? I know there are numerous kits available for hi steer for the stock d30 but I canít find exactly what I need for the d44. I donít want to have to swap knuckles if possible, just looking for the easiest way to correct the drag link.
Any help would be great..Thanks!
1994 YJ under construction....
jamnjeep is offline
post #2 of 13 Old 11-03-2013, 11:39 AM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Originally Posted by jamnjeep
I am considering picking up a pair of 1990 Waggy 44s and going SOA with RE 1.5 SOA springs. Addressing the steering is my biggest concern. I have searched and read numerous build threads but still unclear of the simplest way to correct the steering. I am fine with leaving the tie rod under the springs. But what is needed to run the drag link on top? I know there are numerous kits available for hi steer for the stock d30 but I can’t find exactly what I need for the d44. I don’t want to have to swap knuckles if possible, just looking for the easiest way to correct the drag link. Any help would be great..Thanks!
The cheap way is a dropped pitman arm. Mid priced is a crossover. The proper way is Highsteer
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #3 of 13 Old 11-03-2013, 11:54 AM Thread Starter
jamnjeep
Does anyone make a crossover bracket for the waggy 44?
I currenlty run a drop pitman arm with my SUA lift and also still have the stock yj pitman arm. I dont want to go the drop pitman arm route with SOA, really want the drag link on top. Im just not sure what i need to buy to achieve this??
jamnjeep is offline
post #4 of 13 Old 11-03-2013, 12:09 PM
fratis
fratis's Avatar
Generally in most cases a DPA will not work by itself on a SOA. A Flat top knuckle and arm would be a way to do a crossover.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #5 of 13 Old 11-03-2013, 12:19 PM
Tom95YJ
Tom95YJ's Avatar
http://www.bjsoffroad.com/prod-883.htm
This is for a crossover steering.
Sent from AutoGuide.com App
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #6 of 13 Old 11-03-2013, 12:32 PM Thread Starter
jamnjeep
Thanks Tom! This is what I was after.. Is the type knuckle available off any other D44 I could source in the junk yard or a speciality part only offered aftermarket?
jamnjeep is offline
post #7 of 13 Old 11-03-2013, 12:34 PM
TSEJEEPERS
That is interesting.
Did they still make full size waggys in 1990?
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #8 of 13 Old 11-03-2013, 12:36 PM
TSEJEEPERS
http://77cj.littlekeylime.com/flatop_knucles.html
post #9 of 13 Old 11-03-2013, 01:10 PM
Tom95YJ
Tom95YJ's Avatar
Chevy D44 Flattop knuckles.
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #10 of 13 Old 11-03-2013, 01:11 PM
Tom95YJ
Tom95YJ's Avatar
92 was the last year IIRC they were replaced by the ZJ
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #11 of 13 Old 11-03-2013, 01:29 PM Thread Starter
jamnjeep
Thanks everyone for all the info and links. This was a big help.
jamnjeep is offline
post #12 of 13 Old 11-03-2013, 05:45 PM
fratis
fratis's Avatar
When you look into that aftermarket knuckle find out the distance between the upper ball joint and the drag link mounting hole. Ideally you want this to be similar in length as your pitman arm. Some are quite long an leave you with reduced turning radius.
fratis is offline
post #13 of 13 Old 11-03-2013, 06:14 PM
94chb
i used the stock waggy steering and it worked perfect for my build
94chb is offline
