Looking for insight to determine what causes my drive shaft to wabble. I feel and hear the wabble usually after I let my foot off the accelerator and am approaching a stop. The wabble occurs while in gear AND in neutral. I thought a bad U-Joint was the culprit but a quick replacement job revealed that it was not the cause (at least not that U-Joint). The wabble is felt in the gear shift. Any ideas will be appreciated.
Replace the other u-joint, check to make sure your shaft isn't out of balance, check your tire pressure and or check to see if you have goo in the tires. Also, check your tensioner that connects your tcase to the skid plate. It's very common to grind the nut off.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
