VSS Supply Voltage after 5.3 Swap - JeepForum.com
post #1 of 6 Old 02-17-2013, 12:23 AM Thread Starter
scott66s
I am in the process of wrapping up my 5.3 swap and I am trying to get the speedo working. According to the wiring diagram I have, the jeep ECM would have supplied 8 volts to the VSS. Since I don't have a jeep ECM anymore the VSS doesn't have power right now. Does anyone know if I can supply the VSS with 12V? Or does it have to be 8V? I tried searching and couldn't find anything. Any help or opinions would be appreciated.
scott66s is offline
post #2 of 6 Old 02-17-2013, 06:20 AM
SeanB95YJ
with the 5.3, you should have the ECM for the 5.3, right? use the 5.3s ECM to connect to the VSS the way it would have in the original vehicle
at least that's the way I understand it... I'm using an older engine with a little simpler electronics, so there might be more involved than I'm aware of.
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #3 of 6 Old 02-17-2013, 07:24 AM
beemerkid
If the jeep ecm provided 8V, you will need 8v. You can wire a resistor into the circuit to drop the voltage. I dont remember the formula for how many ohms it would need to be to drop it to 8V. If you run it with 12V your going to burn something up.
SeanB95YJ, He's talking about the jeep vss to feed the speedometer, not the GM vss feeding the GM PCM. The GM PCM is now a separate system from the jeep vss.
beemerkid is offline
post #4 of 6 Old 02-17-2013, 08:43 AM Thread Starter
scott66s
That's what I figured. I was just hoping someone had some experience trying it 12V with it before I had to do, you know, math and stuff.
scott66s is offline
post #5 of 6 Old 02-17-2013, 08:58 AM
rinking
Need more info. What tranny are you useing? I have a Vortec 5.7/ 4l60e in mine. Get ahold of DakotaDigital.com and purchase there sgi-5c sdeedo converter. I used this in Mine and it works perfect. It changes the signal from the gm vss to work with the Jeep speedo. The sweet part is, any time You change tire size or gear ratio, You can go back and adjust it for the right speed. I used My handheld GPS to get it spot on. It's on the money from 0- 80, thats as fast as I've ever drove it, Scary!
rinking is offline
post #6 of 6 Old 02-17-2013, 09:10 AM
rinking
Sorry, just reread everything thats been said. It's coming back to Me now! I remember going over the 8v thing. I couldnt come up with the 8v so thats why I ended up useing the gm vss and Dakota Digital box. I just looked at your profile, If Your using a 4l60e, You must have the vss hooked up. The Dakota box is what You need. Forget about the vss comeing from the 231 and get Your signal from the 4l60e vss.
rinking is offline
