Voltage Regulator or something else?
| GR8TOPS Introduces the Exogate HD Tire Carrier | Truck-Lite's New LED Headlamp Series | RUBICON EXPRESS Lift Kits and Accessories Available at Bas |
#1 | |
Guys, I don't drive my 93 YJ jeep everyday, but I tried to crank it a few weeks ago after it has been sitting for about 3+ months and it would not turn over. I checked and then replaced the battery and the jeep did crank, but now the "Check Engine Light" was on. I also noticed that the voltage gauge was around 10 not in the middle at 14 which is normal. So I took it to autozone and they tested the alternator and said it was not producing anything... so took it off and replaced it... but now everything is the same, the voltage gauge is still at 10 and the CEL is still on. Could it be my voltage regulator? If so should I buy one off ebay or used? And if I do what years are compatible with my 93 YJ 4.0 Auto?
Thanks in advance dUc ![]()
#2 | |
No, you needed to check the alternator off the Jeep before replacing it. Your voltage regulator is built into the ECM, it has complete control over what the alternator does. Since the alternator did not work on the Jeep, you needed to check it off the Jeep to make sure it wasn't the wiring, this goes for any vehicle.
From my FAQ: Testing Alternators: Quote:
95 YJ: SOA, locked 44, locked 8.8, 37s, beadlocks, OBA, winch, and a few other things. [URL=http://www.cdmfabrication.com/aboutmel.html]My Build-Up Post[/URL] -- [URL=http://www.cdmfabrication.com/kbl.html]SWB FAQ[/URL] -- Mike |
#3 |
Thanks for the reply OhioYJ,
Sorry I did not go into much detail on that part but here it is: I had the alternator checked for voltage yesterday.... In fact it is the original alternator.. I had it rebuilt by a local guy, I took it back over to him yesterday and he put it on his "Alternator Testing Machine" "he looked over at me and said its working just fine, it could be your voltage regulator" that is what lead me to believe it's something else going on.. thanks again |
#4 | |
Jello Puddin'
As Ohio said, I'm pretty sure the regulator is built into the alt. If everything is fine coming out and the battery isn't charging, I'd take a look at your wiring.
#5 |
So the 1993 YJ voltage regulator is not built into the CPU?
thanks in advance |
#6 |
Free clues & suggestions
Have you tried pulling the codes yet by cycling the ignition key on & off in sequence?
#7 |
#8 | |
The ECM has complete control over that alternator, there are two little wires going to the back, ^^as I posted above. Both come from the ECM, one of the little wires should constantly cycle between 10-12 volts to keep the alternator voltage inline, as the voltage drops to 13 volts the ECM should jump closer to 12 volts, as it reaches 15 volts the ECM should drop closer to 10 volts, but the ECM does it so quickly, the meter should just jump around between 10-12 volts. The other wire just tells the ECM how much power the alternator is putting out, it is tied to the charging post internally.
#9 |
If you aren't familar with using a multi-meter, take a look through my using a meter writeup:
Multi-Meter Basics
#10 | |
This is why I HATE newer cars. The computer is a single point of failure for all kinds of systems, if any part of it fails, the repair costs are stupendous (instead of 15$ for a voltage regulator). |
#11 |
What kind of battery are you using? The reason I ask is that if my optima red top is completely drained the alternater will not charge it without getting real hot. I have to put it on a charger overnight.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list. www.mijc.org |
#12 | |
#13 |
I put a new battery in the jeep.
OhioYJ ...thanks a bunch on your write ups, I will check all fuses and put a volt meter on the wires leading to the alternator. Just for reference, if I had to replace the ECU --will any ECU work from from 1989-1995 as long as its the 4.0L brain? does it matter if the ECU was auto or manual transmission? thanks in advance |
#14 |
my alternator is just fine i took it to my shop at school and i checked using a tester, the one to put a load on the alt and ext. and it all checked out good, but my gauge is still reading only 10 or 11 and its been like this for id say 5 months or so. maybe just the gauge is out if you replaced the alt and you have no prob now, i dont even look at that gauge now
#15 |
It must be a ECM from a 91-95 4.0L and which ever transmission you have. Part number for the one with manual transmission is 56027368. I just found one for mine on e bay. Good luck! It seems they are a little hard to find. Keep watching e bay. You can also send yours out to have it rebuilt at a number of places.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
