Voltage Regulator - JeepForum.com
post #1 of 9 Old 10-24-2013, 04:01 PM Thread Starter
jeep_attendent
Voltage Regulator
I hope I am in the right place. I have an 89 Jeep Wrangler with lots and lots of modifications. I bought as is so my project now. The Jeep has a 92 Jeep Cherokee engine in it, (242 MPI 4.0L MPFI), with that said the fuel injection was removed and made to a carburetor. The alternator that was on it when bought was on a homemade bracket, on the ac mount, that kept slipping and causing an incredible noise. I put a stock alternator on in the original location and adjusted with power steering point to tighten. It did the trick and no more noise. The new alternator is way different than the one that was there before. Reading this site it got me thinking on the voltage regulator and how to regulator the voltage to the battery. I saw a thread where someone took a Dodge Dakota regulator and wired it to the alternator and it did the trick. I am not sure if this meets my needs or if I need one at all. I am curious to what others can advise. I appreciate the help and be gentle it is my first time.
jeep_attendent is offline
post #2 of 9 Old 10-24-2013, 04:07 PM
YJ4LIFE
so are you using an '89 alternator or a '91+ alternator?
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline
post #3 of 9 Old 10-24-2013, 04:08 PM Thread Starter
jeep_attendent
I have a alternator for the 91 engine.
post #4 of 9 Old 10-24-2013, 04:09 PM Thread Starter
jeep_attendent
sorry meant 92
post #5 of 9 Old 10-24-2013, 04:10 PM
jbolty
jbolty's Avatar
post a picture of the alternator, 1990 and older is a very different animal
jbolty is offline
post #6 of 9 Old 10-24-2013, 04:11 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
An internally regulated alternator with serpentine pulley should work
Luck Favours The Prepared
Anticanman is offline
post #7 of 9 Old 10-24-2013, 04:25 PM Thread Starter
jeep_attendent
Here are some pictures of an alternator, this is not the exact model but what it looks like.
post #8 of 9 Old 10-24-2013, 04:32 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
That's the newer style
post #9 of 9 Old 10-24-2013, 04:47 PM
jsipe007
The newer version of the alternator (what you installed) is externally regulated via the PCM (computer) in 92. Since youve got a carb setup, you will need to wire an external voltage regulator.
I went through a very similar issue. I believe the Dodge regulator fix should work for you since you have no computer CEL to worry about
jsipe007 is offline
