Vibs with my new lift - JeepForum.com
post #1 of 5 Old 02-28-2002, 07:31 AM Thread Starter
Dan Morera
Dan Morera's Avatar
Ok I just finished putting a 2.5"lift with about 1" shackles, I did all the mods to the dif and dropped the tranny about 1" but there's still a lot of vibrations, I haven't put in my 31"s I'm running 215/75/15. What can I do?
YJ Sahara 88, 258 I6, BA/10
2.5" Susp. Lift (Aprox.), 1" Shackles 31x10.5" Cooper
Dan Morera is offline
post #2 of 5 Old 02-28-2002, 11:43 AM
JeepMax
You might have to drop the transfer case a little more - or put in a slip yoke extension or whatever it is called.
Plus, you might want to check your U-joints first - if they are going out it will be an easy fix.
On the other hand - you might have to live with a little vibration, it shouldn't be as bad as you describe though...
Good Luck!
JeepMax
'99 WJ Grand Cherokee Laredo
JeepMax is offline
post #3 of 5 Old 02-28-2002, 01:46 PM
Bob K
Bob K's Avatar
Degree shims. The transfer case lowering tips the tailshaft down. You need to shim the axle yoke upward to match the angle of the driveshaft. The vibration comes from mismatched angles. Also, you may need more than 1" lower trans case for a 3" lift. Personally I would nix the shackle lift. It's not a good thing. Did shims come with your lift kit?
'87 Wrangler YJ 4.2 I6 (sorry, sold)
JuiceBox ignition
2 1/2" ProComp Lift
31" BFG A/T's
K&N Filter
Custom Rock Guards
Turbo Muffler
Rear Track Bar in the shed
Other Tricks I won't tell to just anybody!
'99 Grand Cherokee 4.7 V8
Towing Package
K&N FIPK
ProComp MX6 shocks
Borla Exhaust
Tow Hooks
Alpine CD with Infinity+iPod connect
Just getting started!
If you're not living on the edge...
you're taking up too much space.
Bob K is offline
post #4 of 5 Old 02-28-2002, 02:41 PM Thread Starter
Dan Morera
Dan Morera's Avatar
We actually build must of it ourselves, I did adjust the angle on both ends. It might be U-joints. My vibration is hard only when I'm on first or second gear. Almost none in third or higher. I think we lowered the tcase less than an inch. We were thinking about the 31" when we put it all in, do you think the vibration will be less when I get the 31"s on??
post #5 of 5 Old 03-01-2002, 05:20 PM
Billy Badass
GET A CV DRIVE SHAFT!!!!!
"Nothing like the feeling of braking something important and exspensive"
88' YJ 3" body, 32x11.50 ProComp Mud Terrain. JKBII Carb Mod. Nutter Bypass and a new ignition. White Faced Gauges with blue backlighting. Sone to come 4.10 gears and lockers.
Billy Badass is offline
MORE MML help with vibs? flame0086 YJ Wrangler Technical Forum 7 10-19-2009 12:50 PM
2" Bb Lift W/ Vibs,how Much Tc Drop? RJV TJ Wrangler Technical Forum 20 12-29-2007 09:18 AM
Lift and vibs skip97 TJ Wrangler Technical Forum 8 02-24-2007 12:46 PM
rather odd vibs from lift RnEmOvr YJ Wrangler Technical Forum 3 11-01-2005 01:42 PM
How much vibs?? Dan Morera YJ Wrangler Technical Forum 4 04-29-2002 07:13 AM
