Vibrations in rear need a direction - JeepForum.com
post #1 of 10 Old 03-30-2013, 08:33 AM Thread Starter
Benzfrd
Just to get an understanding for my jeep. I have a 94 YJ. It has a 4.0 and its a 5 speed manual. I have installed a 4" rubicon lift, 8 degree shims , hack and tap, an xj front front shaft cut and balanced for my new rear, 33" tires, T-case drop kit, 1 1/4 lift shackles front and rear.
So now down to the problem. So when I put on the lift it had a massive vibration in the rear so naturally I needed a new to me drive shaft and went with a hack and tap. After that the vibrations went down alot but it was still there so I upped to the 8 degree shims instead of the 4s that came with the kit. This again reduced the vibrations. But it was still there at 35mph.
After some looking I seen the cv was a little close on the rotation to the knucles so I installed the T-case drop kit that came with the lift and it almost eliminated the vibes. But they were now only there at 55mph and on low rpm starts.
I was ok with it but decided have the mechanics look at it while fixing some other things. They said that I had to come up 4 more degrees on the rear axle. I told them that I have new shackles that would lift it more and they said that would give me more angle and be enough to get me in a safe operating angle. So I got the shackles yesterday and installed them.
Now the vibrations are as bad as before I installed the t- case drop kit. It looks to me like the cv is bottoming out and on load from the vehicle when driving its rubbing and causing vibes. It gets worse as speed increases. The mechanic did say my cv was going bad but this seems alot worse then a just starting to go bad CV. I took some pics and will be changing into the new CV tuesday but I was wondering what you guys think
Benzfrd is offline
post #2 of 10 Old 03-30-2013, 08:36 AM Thread Starter
Benzfrd
Here are the pics
Benzfrd is offline
post #3 of 10 Old 03-30-2013, 09:06 AM
Tarpo
Do you have a slip yoke, AND a cv shaft? That what it looks like on my I phone.
Tarpo is offline
post #4 of 10 Old 03-30-2013, 09:22 AM
SnowdogMarc
Did you replace all the U-joints when you had the shaft shortened? I'm running a 2" BDS with 2" BL and 1.5 shackles and a 8.8 with SYE and NO TC drop with not a single vibration. I'm thinking it's the XJ shafts U-joints as well.
l We're here for a good time. Not a long time. So have a good time the sun can't shine every day.
l_______
/l ,[_____],
l---L -[]lllllll[]-
()_) ()_)--o-)_)____________VE6-SDG
SnowdogMarc is offline
post #5 of 10 Old 03-31-2013, 08:02 AM Thread Starter
Benzfrd
I do have a slip yoke in the driveshaft its bellow the cv joint.
Benzfrd is offline
post #6 of 10 Old 03-31-2013, 08:07 AM Thread Starter
Benzfrd
I did replace all of the u joints when I got it cut and balanced. I know this seems weird and they say every jeep is different but this thing seems to be different in the way of the worst in each. Seems I am always getting the bad end of the result and have to do all the work
Whatever its a jeep and im glad im just down to small things like chasing small vibes
But i drove it around yesterday all day and the vibes werent to bad but at 50-55 mph the vibes were there and I can really strt to hear this CV going it has a clunking sound every once in awhile on the rotatings... does that make any sense?
Thank you for you time and any replies
Benzfrd is offline
post #7 of 10 Old 04-01-2013, 05:41 AM
alc60560
Replace the cv, you should only need first peice with the ball. Napa has them
alc60560 is offline
post #8 of 10 Old 04-01-2013, 06:41 AM
bogleparsons
check with angle finder.
What angle is your driveshaft? what angle is your pinion yoke? it looks high to me....
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #9 of 10 Old 04-01-2013, 09:31 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Check your driveshaft
https://youtu.be/uwMQTr_BpTY
Luck Favours The Prepared
Anticanman is offline
post #10 of 10 Old 04-01-2013, 03:14 PM Thread Starter
Benzfrd
Thanks guys for the advice. I dont know the angles and I have to buy a tool to do so the right way. Unless you guys know another way ?
Benzfrd is offline
