vibrations in front axle and 4wd light stays on - JeepForum.com
post #1 of 3 Old 06-24-2010, 08:25 PM Thread Starter
yoyoyo109
2015 JK Wrangler
about a week ago, i was driving along a bayou on grass(i was in 2WD at the time) when a large mound covered with grass came out of no where and i flew about 4 feet in the air. i initially was afraid that i mightve broken something but all that i noticed were my wheel fenders popping off so i thought nothing of it. earlier today, i went into 4WD to get better traction in the rain and then once it stopped i took it out, but the light stayed on. i jacked it up and checked the tires and the vacuum lines and even though the lights on, only two tires are moving. i took the vacuum lines off and only one is getting suction and thats the one that is NOT attached to the transfer case. i also noticed that around the time of the light staying on, there was a fierce vibrating in the front axle when going around 55mph which couldnt be from the jump because i could easily drive fast after it and this only started today. are these problems related? and does anyone know how to fix them?
yoyoyo109 is offline
post #2 of 3 Old 06-24-2010, 10:18 PM
MJMPC
If you think it is locked in4 WD dont drive it on blacktop.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #3 of 3 Old 06-24-2010, 10:33 PM
beachedjeepyj
Sounds like your cad didnt disengage and the vibes are probably from the unbalanced drive-shaft turning all the time. To test this out jack up the passenger front tire leaving the driver front tire on the ground, do this with the engine running and in nuetral and t-case in 2wd. you should be able to turn the passenger front tire freely, if not you are in 4wd and it is a problem with your linkage. If you are able to turn the tire freely look at the front drive shaft it should not spin with the tire, if it does spin that means your cad in stuck in the locked position and that should be your problem.
Your front axle is a two peice axle and is unlocked in 2wd alowing the tires to spin without the gears and driveshaft turning. It is controlled by a vacuum actuated cad that slides a fork over to lock the axle together when you put the tcas in 4wd. Im guessing this fork was damaged and isnt allowing the axle to unlock.
Id pop open the cad and take a look to see if the fork can move freely.
Originally Posted by Jeep89JV View Post
Do I let others drive my rig? No -- Why, because if this ship sinks i'll be the captain and I go down with this ship.
beachedjeepyj is offline
4wd , front axle , vacuum lines , vibrations
gas light stays on jeepinat15 TJ Wrangler Technical Forum 4 04-29-2010 09:28 PM
Cab Light stays on six-gun TJ Wrangler Technical Forum 9 01-20-2010 10:08 AM
4wd light stays on when in 2wd chriss YJ Wrangler Technical Forum 1 05-10-2005 03:29 PM
4x4 Light Stays On deltony007 YJ Wrangler Technical Forum 0 07-07-2004 10:58 AM
4wd light stays on Ex CCS Racer YJ Wrangler Technical Forum 4 08-18-2003 06:53 PM
