Vibrations after TC drop? - JeepForum.com
post #1 of 7 Old 04-26-2010, 08:57 PM Thread Starter
97Xj_Sport
Helped a buddy lift his yj (rusty's 4") put the six degree shims in and it drove fine, with just a little vibration. We put on the TC drop a week later to get rid of all the minor vibes an after we finished we drove about 15 miles to a best buy and it drove fantastic, no more vibes, no wobble. On the way back to his house it started to vibrate more than before the TC drop when he would accelerate when going 60 and above, made sure everything was tight but still has the same problem. Any guesses? Thanks.
97 XJ 2 door sport- 3" Rusty's lift, 31" MTR's
97Xj_Sport is offline
post #2 of 7 Old 04-26-2010, 09:03 PM
moonshinefuel
U-joints, they develope wear patterns in the needle bearings when driven so long at a certain angle. Replace with new Spicer U-joints. (My guess)
moonshinefuel is offline
post #3 of 7 Old 04-26-2010, 09:03 PM
MoparFreak69
U joints wore into the pattern of how the joint flexed at the stock height. Lifting it moved the pivot spots and the joints are moving from a worn spot to a non worn spot. Try replacing the u joints and the problem should disappear.
EDIT: Moonshine beat me to it!
90 YJ 5.2 Magnum, AX-15, 231 SYE'd
D44 front, welded/trussed AMC20HD rear. 4.56 gears soonish.
Western 6 lug aluminum wheels, with 35x12.50x15 Wrangler MTRs
MoparFreak69 is offline
post #4 of 7 Old 04-26-2010, 09:06 PM
moonshinefuel
Beat ya to it moparfreak.
post #5 of 7 Old 04-26-2010, 09:10 PM
88blkyj
hey U joints!
oh sorry...
88blkyj is offline
post #6 of 7 Old 04-27-2010, 02:30 PM Thread Starter
97Xj_Sport
Thanks guys, don't know why I didn't think of that.
post #7 of 7 Old 04-27-2010, 03:31 PM
clush
Good Info, I am putting a 4" lift on and I will prolly just go ahead and replace the u joints while I have all the tools out. Didn't think of that one either, but it makes sense.
clush is offline
Transfer Case Drop Question...To drop or not to drop? dswi YJ Wrangler Technical Forum 11 07-24-2009 02:33 PM
Transfer case drop or skid plate drop? JIME TJ Wrangler Technical Forum 2 04-08-2009 06:10 PM
looking for drop pitman arm with more drop than typical 4" DPA swa240z YJ Wrangler Technical Forum 3 04-18-2008 12:35 PM
NO vibrations after removing x-fer case drop? FLATFENDER54 TJ Wrangler Technical Forum 9 03-31-2008 05:39 PM
T-Case Linkage Pivot Drop Bracket Nessisary for 2.25"BB W/ TCase Drop jbpdog TJ Wrangler Technical Forum 1 06-27-2006 07:16 AM
