Vibrations - JeepForum.com
post #1 of 3 Old 01-30-2002, 04:13 AM Thread Starter
bonehead99
bonehead99's Avatar
Vibrations
I have a vib in the front under the driverside, It only occurs when taking off and more when turning. The rear vibs from 45-60 mph. I am thinking of having a 1/2" cutoff my shackles and installing degree shims. What size shim should I get? Also I want to replace the ujoints in the drive shaft. Should I get sealed or greasable?
94 YJ 4.0 HO 3sp Auto, 3" RC Lift, 1" Shackles, 3" BL, 31x10.50, Pacesetter Armor-Coated Header, Homemade Air Intake w/ K&N
bonehead99 is offline
post #2 of 3 Old 02-06-2002, 01:21 PM
B2hi
Sounds like the drivers side axle joint is bad. Turn wheels all the way to the right. Reach in and see if you can wiggle the joint back and forth. Does it clank. Not good. Replace the shaft. Don't bother replacing the joint. too much work and can be more expensive if you take it somewhere.
87 Wrangler 4.2
Mopar MPI
4.0 Head
Throttle body spacer
K+N air filter
Con-ferr shackles,R.E. 4.5 lift with 33x12.5 BFG Muds and 1in. body
B2hi is offline
post #3 of 3 Old 02-06-2002, 07:36 PM
osburn
osburn's Avatar
Sounds like a u-joint to me. Check them all. Replace the ones you need to. Save the joints for spares if you aren't already in the habit of carrying new ones for spares.
It could also be a bearing problem I suppose. But I'd start with the joints. Check the bearings on the front by jacking up the tire and shake it side to side. A very small amount of movement is ok. There will be no doubt if it's bad.
Matt Osburn
Score 1032
osburn is offline
Help with vibrations, not DW! Gold03TJ TJ Wrangler Technical Forum 2 09-11-2007 08:50 PM
Vibrations JEEP-DADDY TJ Wrangler Technical Forum 1 06-22-2007 09:17 AM
Vibrations jmhat98 YJ Wrangler Technical Forum 4 05-16-2007 11:15 AM
Vibrations above 70 MPH tomkirkland4 TJ Wrangler Technical Forum 7 04-12-2006 02:05 PM
vibrations 90roughcountryj YJ Wrangler Technical Forum 3 06-06-2004 04:40 PM
