Vibration, Knocking AFTER SYE install - JeepForum.com
post #1 of 3 Old 05-08-2006, 10:46 AM Thread Starter
Leroux
Leroux's Avatar
After I installed my SYE and and started the heep up to move it i noticed that there is a vibration or knocking in the drivetrain while sitting still or moving. I only have the front shaft installed, getting the rear shaft worked on today. The only two things I have thought about is that the jeep hasent been started in about 3 weeks, longest ever and everything was just cold from sitting? Or that my exhaust is sitting on my tranny/transfer case skid plate, because I had exhust done wile I had the transfercase drop.
Thanks.
'93 YJ 4.0 i6, 8.8ls, D30 w/Aussie & Alloy USA shafts/disco removed, 4.56's, 3.5" Fabtech (gathering parts for SOA), 5/8 MORE Boomerangs, SYE, Coast Driveshaft, m8000, "Accordion style" Header w/full exhaust, 33" Siped BFG MT's, TJ Flares.
Leroux is offline
post #2 of 3 Old 05-08-2006, 07:57 PM Thread Starter
Leroux
Leroux's Avatar
Any Ideas?
Leroux is offline
post #3 of 3 Old 05-08-2006, 07:59 PM
Tomb Raider
Addicted...
Tomb Raider's Avatar
This would be my first assumption. But you know what assumptions get you.
I like to build stuff. Want to know what I build, you can google it HERE
Tomb Raider is offline
Knocking under my feet when taking off after the BL/MML install? chaznad TJ Wrangler Technical Forum 3 05-21-2009 08:22 PM
2" Lift - Front Vibration/Knocking Issue After Lift cmorra68 TJ Wrangler Technical Forum 2 04-30-2009 09:12 PM
violent vibration and knocking sound. majkowskid TJ Wrangler Technical Forum 24 04-29-2008 02:11 PM
Unknown knocking/vibration rwjeep TJ Wrangler Technical Forum 2 07-02-2007 01:09 PM
Knocking after AA bracket install wenkebach TJ Wrangler Technical Forum 1 04-30-2006 07:58 PM
