Vibration and brake knocking - JeepForum.com
post #1 of 1 Old 01-05-2012, 07:18 PM Thread Starter
jeeprookie15
1987 YJ Wrangler
So i put this lift kit on my yj http://www.jeep4x4center.com/jeep-li...s-lift-kit.htm
and some 33" tires. After i put on the lift kit and took it for a drive it had these massive vibrations that started at around 45 mph. I thought my wheels needed to be realigned so i took the jeep in to get the wheels aligned. When i drove it after they were aligned the vibrations werent quite as bad and now it only vibrates bad when i let off of the gas in 4th and 5th gear. When i accelerate it doesnt really vibrate much. There is also now this knocking noise on the brakes when i press them at low speeds (like under 20 mph.) When im running faster and press them it doesnt make the noise though. Can anybody help me out on anything here
also im running a stock driveshaft
jeeprookie15 is offline
knocking , vibration
Knocking noise when I begin to brake DylanAndre TJ Wrangler Technical Forum 6 02-23-2011 10:57 AM
2" Lift - Front Vibration/Knocking Issue After Lift cmorra68 TJ Wrangler Technical Forum 2 04-30-2009 09:12 PM
violent vibration and knocking sound. majkowskid TJ Wrangler Technical Forum 24 04-29-2008 02:11 PM
Unknown knocking/vibration rwjeep TJ Wrangler Technical Forum 2 07-02-2007 01:09 PM
Vibration, Knocking AFTER SYE install Leroux YJ Wrangler Technical Forum 2 05-08-2006 07:59 PM
