Vibration at 45 MPH - JeepForum.com
post #1 of 21 Old 08-25-2004, 06:18 AM Thread Starter
jeep1703
Vibration at 45 MPH
Hey guys got a question for yall hope someone can help. Let me start off by telling you what I am running. I have a 90 Model YJ with a 4.2 and automatic transmission. Have the stock gears and running 33" tires. OK when I am running at 45 MPH I get this vibration in the dash, well actually all over. Now if I let off the gas down to about 40 or speed up to about 50 all of the vibration goes away. I though that it might be the transmission lugging from having the bigger tires but I still have power when I give it a little gas. I also had the idea that maybe the driveshaft has gotten out of balance somehow. But that raises another question can a drive shaft just go out of balance, and if it does will it vibrate at just certain speeds. I also think but not for sure it might be in the transmission which has 155,000 miles on it. I don't know any help would be appreciated.
Thanks,
jeep1703 is offline
post #2 of 21 Old 08-25-2004, 06:22 AM
CAJUN_YJ
CAJUN_YJ's Avatar
lift
Are you running any lift?
CAJUN_YJ is offline
post #3 of 21 Old 08-25-2004, 07:09 AM Thread Starter
jeep1703
Ya I have a 3.5" BDS suspension lift.
jeep1703 is offline
post #4 of 21 Old 08-25-2004, 08:20 AM
BamaJeeper
BamaJeeper's Avatar
You have a toasted u-joint.
Out of the darkness comes light.
BamaJeeper is offline
post #5 of 21 Old 08-25-2004, 09:01 AM Thread Starter
jeep1703
Thanks guys I will check my U-joints and let you know.
jeep1703 is offline
post #6 of 21 Old 08-25-2004, 12:40 PM
OlllllllO Jeep1
Thanks,
I have this same prob but all my u-joints and axle joints are fairly new, What I dont get is when I downshift into 3rd it goes away, So basically I can go the same speed in the lower gear and not get the vibration. That leads me to believe that the engine is out of its powerband. But then again I am not a mechanic. Let us know what you find. I have a 91 YJ with a 3" lift and a Transfer case drop and 32x11.50 inch Goodyears.
OlllllllO Jeep1 is offline
post #7 of 21 Old 08-25-2004, 03:00 PM
GreenReaper93
GreenReaper93's Avatar
I'm not sure where I read it, but after you lift your vehicle your suppose to loosen your tranny from the skid plate, take it around the block then tighten it back up. I'm guessing it settles the tranny for the new angle? Anyone heard this, or an I actually losing it.....
GreenReaper93 is offline
post #8 of 21 Old 08-25-2004, 05:36 PM
BIG KEV
I have this problem too. My vibration ( more like wobble) seems to be coming from the front. My front wheels seem to wobble side to side moving the front end of the jeep.
I have a 95 yj with a BDS 3.5in lift, tranfer case drop, sye and new tom woods drive shaft, and 33x12.5's.
HELP?????
Punisher 95 YJ
SOA 103' WB 40" IROKS
Kingpin HP60 / 60 5.13's locked
KORE4x4CUSTOMS.com
BIG KEV is offline
post #9 of 21 Old 08-25-2004, 05:42 PM
TSEJEEPERS
If you have had the lift on for a while and did not have any problem when it was installed check to see if your tires are balanced, u joints, and transmission mount. If you still have the stock transmission mount replace it. You will have to adventully anyway. Also check your tie rod ends and alignment. As always start with the cheapest thing and move on.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #10 of 21 Old 08-26-2004, 04:27 AM
BamaJeeper
BamaJeeper's Avatar
Bad idea! That's a good way to destroy the motor mounts. The only reason to loosen the tranny mount and "settle" it would be if a motor mount lift were installed but you sure a hell would'nt want to drive it with a loose mount.
post #11 of 21 Old 08-26-2004, 04:30 AM
BamaJeeper
BamaJeeper's Avatar
HELP?????
Stick your head out and watch the tires while you drive. If the they shimmy then it's time for new tie rod ends.
post #12 of 21 Old 08-26-2004, 04:32 AM
BamaJeeper
BamaJeeper's Avatar
How new is "fairly new"? Get under there and give those u-joints a good shake. Got slop? If you do it's time for new u-joints.
post #13 of 21 Old 08-27-2004, 04:45 PM
BIG KEV
Thanks for the help! I'll check the tie rod ends. By the way how do I do that?
Thanks
BIG KEV
Punisher 95 YJ
KORE4x4CUSTOMS.com
BIG KEV is offline
post #14 of 21 Old 09-21-2004, 03:38 PM
mbiusa
Vibration through transmission
" have a 90 Model YJ with a 4.2 and automatic transmission. Have the stock gears and running 33" tires. OK when I am running at 45 MPH I get this vibration in the dash, well actually all over. Now if I let off the gas down to about 40 or speed up to about 50 all of the vibration goes away. I though that it might be the transmission lugging from having the bigger tires but I still have power when I give it a little gas."
I have 90 YJ 4.2 Auto with 4" lift and 33" tires and have exactly the same symptoms. My local 4-wheel drive garage mentioned it was more typical with auto transmission as the auto box is longer and that makes the angle of drive shaft universal joints to rear end more acute. Lifting the vehicle caused the problem in the first place, the fact that its got an auto box makes it worse. Although joints maybe going, they will go again unless you can reduce angle of drive shaft joints by dropping transfer box using spacers (washers) - that is what I was told - hope this helps!
mbiusa is offline
post #15 of 21 Old 09-21-2004, 04:03 PM
tobias94yj
Hillbilly Member
tobias94yj's Avatar
if you do a tc lowering kit then you will have to loosen those bolts where the tranny mounts the the skid plate. I could not get mine into 2, 4, or reverse until i did that. then i ditched the tc lowering kit and did the sye
To view the NEW
click here!!!
tobias94yj is offline
Bad Vibration. Please Help? metal_kid17 YJ Wrangler Technical Forum 8 10-26-2009 02:52 PM
Bad Vibration. Manard TJ Wrangler Technical Forum 3 02-25-2008 05:26 PM
Odd vibration JeepPirate TJ Wrangler Technical Forum 4 01-14-2008 12:03 PM
vibration igolf JK Wrangler Technical Forum 20 12-17-2007 07:26 AM
Vibration henri TJ Wrangler Technical Forum 13 04-13-2005 07:25 AM
