Vibration at 35mph-40mph - JeepForum.com
post #1 of 6 Old 10-10-2013, 04:56 AM Thread Starter
Brick24
Hey Guys,
Took my 87 YJ out wheeling last weekend and on my way into work the next day I found I had a not so fun vibration at 35mph. The whole jeep isn't really vibrating, but the dash is and making a lot of racket. I crawled underneath and poked around, looks like my u joints are ok, no shiny spots on my rims anywhere, but there's some play (not rotational) from my drive shaft as it leaves the t case. Is that normal? Do I just need to replace the bushings/bearings there? There’s no lift, just 30” tires.
My passenger front wheel bearing needs to be replaced as well, but that's been that way for a while so I don't really think that's what is causing the vibration (parts are on their way).
Thanks for any insight!
Brick24 is offline
post #2 of 6 Old 10-10-2013, 11:18 AM
superj
thats an odd speed to have a vibe at. mine started doing it at 30mph when i lifted it the other day so i would check that driveshaft again, maybe that movement is a no-go?
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 6 Old 10-10-2013, 11:26 AM
Reno72
Play side to side is not normal for the driveshaft. I'm assuming your talking play at the rear u joint/yoke and not the output shaft, although side to side play at the output shaft is not good either?
Reno72 is offline
post #4 of 6 Old 10-10-2013, 12:58 PM Thread Starter
Brick24
This is play at the output shaft, before the u joints. It's not much play, but enough to wiggle a little. Is there a bearing in there that could be failing that would cause it?
Brick24 is offline
post #5 of 6 Old 10-10-2013, 02:22 PM
bpounds
bpounds's Avatar
Check your wheels for mud. It's a long shot, but I have personally experienced that, and you did just go out wheeling before it started. Check for missing wheel weights too.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,GM HEI Ign, 5 Speed Peugeot, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
post #6 of 6 Old 10-10-2013, 02:30 PM Thread Starter
Brick24
Haha, no mud out here. Checked for shiny spots on the wheels, didn't see anything.
Brick24 is offline
drive shaft , transfer case , vibration
