Vibes after 4" RC lift - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Vibes after 4" RC lift
DIY tube fender kitsAmsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, Ba
Unread 07-07-2008, 07:00 PM   #1
berman95
I just finished installing my RC lift. And now I have some slight vibrations. How do I know if its coming from the driveline angle?
berman95 is offline   Reply With Quote
Unread 07-07-2008, 07:05 PM   #2
Mean Max
Don't poke the bear
Mean Max's Avatar
It is, because you just changed the driveline angle by quite a bit. Consider SYE/Cv shaft, and possibly a 1" MML (if you have a body lift, 1" minimum) and/or a 1" T-case drop.
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline   Reply With Quote
Unread 07-07-2008, 07:08 PM   #3
lurkeryj
1997 XJ Cherokee
its not definately from the drive line. i installed it on mine and my driveline is fine. it could be, but not definately. if you read the instructions that came with the lift it says something like it may be necessary on some vehicles to cut the plate around the shifter back a little to allow the vehicle to properly shift into 2nd and 4th. iv heard of a couple people with vibes cause even though their jeep is in 2nd, its not in 100%. check that and check to make sure your u-joints are good and everything before you get too crazy with it too. oh yeah, and if you installed larger wheel/tires on your rig, it could also be out of balance wheels. just my .02
lurkeryj is offline   Reply With Quote
Unread 07-07-2008, 07:11 PM   #4
Burnerman
If you didn't have vibes before the lift then it's a good bet it's driveline angle. I lifted mine 3" and get little to no vibes with the transfer case drop installed. Check the trans and engine mounts. If they're old, oil soaked or dry rotted they may some of the cause. Jack the body of the Jeep up so the suspension is at full droop. ( block the front wheels and use proper safety) With the Jeep in neutral spin the rear driveshaft by hand and see if the u joints bind at all. If they do you found the trouble.
[SIZE="3"]89' YJ Larado 4.0L,AX15
01' Grand Cherokee 4.0L
[/SIZE]
Check my Gallery for pics.
[URL="http://www.jeepforum.com/forum/f12/my-unbuild-rebuild-988762/"]My Rebuild Thread[/URL]
[SIZE="2"][COLOR="Blue"]Take a minute and fill out your profile, Please[/COLOR][/SIZE]
Burnerman is offline   Reply With Quote
Unread 07-07-2008, 07:12 PM   #5
Mean Max
Don't poke the bear
Mean Max's Avatar
I believe you, that you didn't have problems with vibes after your lift. But usually it's a crap shoot, some do, some don't. He just installed a 4" lift, now he has a vibe. If I were placing a bet, I'd say you just got lucky, and he didn't. It's just a roll of the dice.
Unread 07-07-2008, 11:21 PM   #6
Barrio
did you install the t-care drop with the kit?
www.offroadjunkies.net
www.pgh-offroad.com
-OD Green/Flat Black 92' 4" Rough Country Lift, tons of crap.
-Rio Red 1995 Ford Mustang- Daily Driver
Originally Posted by alfmoney
i see theres a bunch of toughguys on this forum or internet gangstas
Barrio is offline   Reply With Quote
Unread 07-08-2008, 05:57 AM   #7
Rough Country
^^ my thoughts exactly, if you did check your u joints sometimes the slight change in angle will cause them to vibrate.
Rough Country is offline   Reply With Quote
Unread 07-08-2008, 09:30 AM   #8
Brown Dog
Vendor
Brown Dog's Avatar
Go to this page,
http://browndogindustries.com/frequent-questions.aspx
and click on the links about 2/3 down the page. This will help you understand the driveline angle situation.
Brown Dog Offroad
http://www.browndogoffroad.com
The Jeep Forum Discount is ON!!
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% HANDCRAFTED IN AMERICA
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
3.5" Superlift SL
AA SYE
35" GoodYear Mud Terrains
Conteract Balancing Beads
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline   Reply With Quote
Unread 08-21-2008, 01:26 PM   #9
Toms87
1987 YJ Wrangler
I'm pretty close to buying the rough country 4" lift. If i get that and do their 1" boomerang shackles, what's the probability i will NEED a slip yoke eliminator? I figure the driveline angle will be way different than before but how much different?
Toms87 is offline   Reply With Quote
Unread 08-21-2008, 01:44 PM   #10
jgillespie
it would be your best bet to get a SYE and CV driveshaft because the drop will not take care of all the vibes most likely. ...and it's just a good investment to get one
'91 YJ 4.0 3/4'' Brandon Booms 31/10.50 BFG AT Herc'd CJ dash/tailgate CJ5 seats 4KCs cracked windshield
RED JEEP CLUB MEMBER 536
Originally posted by Crazyquadder:
a 6 foot puddle is approx half way up my doors
jgillespie is offline   Reply With Quote
Unread 08-21-2008, 03:06 PM   #11
Bigboyky
I have the RC lift also with no vibes. Now after the 3/4" booms I have just a little. Like it was said above it's a crap shoot.
Bigboyky is offline   Reply With Quote
Unread 08-21-2008, 07:12 PM   #12
Barrio
Are you running the TC drop with those 3/4" booms?
www.pgh-offroad.com
Unread 08-21-2008, 08:26 PM   #13
butlerbullies
1987 YJ Wrangler
I installed the RC 4" kit w/ T-case drop just weeks ago and I had really bad vibes. I drove it around the block a few times then crawled back under to find that my T-case was rubbing on the skid plate on drivers side rear. I notched out the skid plate and the really bad vibes are now only in 3rd and almost tolerable. I ordered the 1.25" BL from JKS w/budget 1" MML and that should help.
Then I went crazy over the weekend and purchased a used AX-15 w/T-case to replace my BA-10(123k and still shifting), I also bought the SYE kit w/Woods Drive shaft. I can't wait to tear it all apart and put it back together again.
butlerbullies is offline   Reply With Quote
Unread 08-21-2008, 11:56 PM   #14
Toms87
1987 YJ Wrangler
How much does a SYE and tom woods drive shaft usually run? i'm pretty much broke after the lift and tires for at least a couple weeks.
Unread 08-22-2008, 01:02 AM   #15
K4KAS
http://www.4xshaft.com/index.html
K4KAS is offline   Reply With Quote
