vibes at 25-35 mph - JeepForum.com
post #1 of 4 Old 03-14-2010, 12:27 PM Thread Starter
ratfink4545
vibes at 25-35 mph
im getting vibration when accelerating mostly, i know its not alignment or tires needing to be balanced because it stops if i shift to neutral. Im thinking maybe U joints? i took a look at them and they dont seem to have any wear & tear
any ideas?
everything looks better through a plastic window
ratfink4545 is offline
post #2 of 4 Old 03-14-2010, 12:47 PM
moonshinefuel
It depends on if the tires, or one tire might be damaged, or, out of roundness so to speak. You could balance a tire all day long but if it has damage somehow. It will still wobble. Sometimes tires have uneven wear, truckers shave tires on a machine to even that out. Though, not sure in your case of what your dealing with because you say it is mostly on acceleration. I knew someone one time who was going nuts trying to figure out a wobble, changing tires out, u-joints, etc. Turns out it was an axle shaft that was not straight, it had a bend in it that was causing vibration wobble, so to speak. It may just be a u-joint, as you say it is more noticeable on acceleration.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #3 of 4 Old 03-14-2010, 02:15 PM
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Avatar
leaf bushings maybe.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
post #4 of 4 Old 03-14-2010, 03:02 PM
Burnerman
Burnerman's Avatar
Trans mount and or u joints. drop the driveshaft and check the joints. You may have a dry cap or 2. You won't feel the play when the shaft is installed.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
u joints , vibrations
MML vibes vs. Driveline Vibes??? iceman123187 TJ Wrangler Technical Forum 2 03-12-2010 07:04 PM
What is the diff between driveline vibes and wheel/tire balancing vibes chaznad TJ Wrangler Technical Forum 14 05-05-2009 09:07 PM
Vibes 00jeepsahara TJ Wrangler Technical Forum 3 08-01-2007 11:32 AM
got lift no vibes,now vibes? what could have happened? kaketj TJ Wrangler Technical Forum 6 01-23-2005 04:17 PM
No vibes after BB! CRASHED... now I got vibes!?!?! thejafe TJ Wrangler Technical Forum 12 08-23-2004 09:18 AM
