Versions/Significant Changes? - JeepForum.com
post #1 of 2 Old 07-21-2003, 09:54 PM Thread Starter
Alien
Alien's Avatar
As I mentioned in my other thread, I'm looking to buy a Wrangler. Can someone tell me the difference between cj, yj, etc?
Also, when were the last redesigns of the chassis, engine, drivetrain and suspension? For example, is a '97 pretty much the same thing as an '02? I'm probably looking at getting a '00 or '01, but may end up with a '98 or '99.
Any other significant differences and general shopping advice is appreciated.
Alien is offline
post #2 of 2 Old 07-21-2003, 11:07 PM
jeepinkg
The CJ was first then that was improved a little with the YJ version in 87 both use leaf springs under the axle then again in 97 when the TJ was introduced.there are very few diffrences between the cj's and yjs. the most significant change was the use of coils in 97 on the TJ's they also started hvae a rear Dana 44 as an option and depending on if you plan to run larger than 33's would be something to look for. Those are the most noticable changes. good luck with your search.
95 YJ
2in body, TJ flares,32's, detriot true trac up front, powertrax no slip rear, mile marker winch, and more
current projects
400 big block, ford 9, dana 60, and some more lift
jeepinkg is offline
significant drop in mileage Sungard YJ Wrangler Technical Forum 2 11-16-2008 09:19 AM
Significant differences between a 98 and 2001? Z0RR0 TJ Wrangler Technical Forum 17 05-01-2007 10:32 AM
significant gas smell....help! PatTJ05 TJ Wrangler Technical Forum 8 02-22-2007 04:53 PM
would a diesle get a significant gain in mpg? David Hinton JK Wrangler Technical Forum 16 10-06-2006 10:30 AM
my most significant mods onemoretry TJ Wrangler Technical Forum 4 01-29-2006 09:39 PM
