Vent setting won't work with fan - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Vent setting won't work with fan
OPTIC ARMOR WINDOWS all sale now !!!!!!!!Alloy USA and Posi-Lok Cable Axle Disconnect Kits Dana 30 Spartan Locker Special Forum Prices Dana 30 44 60 Ford 8.8
Unread 03-11-2014, 08:00 AM   #1
wrangler_bear
Gotta simple question to ask about my yj vent setting. When selected, should the fan activate as well like it does for heating and cooling? If not, would it be possible make this happen? Would be nice to have forced vent air.
wrangler_bear is offline   Reply With Quote
Unread 03-11-2014, 08:58 AM   #2
bpounds
bpounds's Avatar
Fan does not run on vent. Fan runs on heat and defrost only.
Can't say about mod potential.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Carter BBD carb, 5 Speed Peugeot, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline   Reply With Quote
Unread 03-11-2014, 11:48 AM   #3
Michaelgoesrawr
Michaelgoesrawr's Avatar
I don't believe it will work because I think the fan blades are in the way when it's vented. I remember playing around with it when the fan was on trying to adjust the flaps and I got that nice grind sound when I manually moved the flaps.
If you want more force with your vent, pick up a hood vent scoop. It collects air that bounces off the windshield.
http://m.quadratec.com/products/prod...p?pid=13006+12
Help our dog Bo! https://fundly.com/give-bo-a-chance
Michaelgoesrawr is offline   Reply With Quote
Unread 03-11-2014, 01:34 PM   #4
Old4X
1990 CJ7
As noted, no fan assist on vent, ram air only
Rust free YJ for sale. Need more room in barn.
Old4X is offline   Reply With Quote
Unread 03-11-2014, 02:35 PM   #5
KKiowaTJ
Glad I like to sit and lurk lmao. I couldn't remember if the vent was forced air or fan kicks in. Now I know why on vent it does nothing, Only heat and defrost. Saves me time, Thanks OP for asking
YJ, TJ, XJ, ZJ..... I like jeep's too much!
KKiowaTJ is offline   Reply With Quote
Unread 03-11-2014, 02:41 PM   #6
wrangler_bear
Ha...got it already
Unread 03-11-2014, 02:44 PM   #7
bpounds
bpounds's Avatar
I suppose the engineers figured a Wrangler already has all the ventilation one could ever ask for.
Bill
Unread 03-11-2014, 02:56 PM   #8
wrangler_bear
No biggie. Just in the process of completing my jeep. Last item is to change the speedometer gear cuz I went from 4.10 to 4.88.
Unread 03-11-2014, 02:59 PM   #9
Anticanman
Follow Me
Anticanman's Avatar
They can be reversed to limit the amount of air coming in as well.
Luck Favours The Prepared
Anticanman is offline   Reply With Quote
Unread 03-11-2014, 06:25 PM   #10
baritone_mike
Speedo should be correct assuming you did not change the speedo gear when you put the tires on. 4.10's and stock tires = 4.88's and 33's
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
baritone_mike is offline   Reply With Quote
Unread 03-11-2014, 06:57 PM   #11
wrangler_bear
From what I can see, its only about 2 mph off. Maybe the 41 tooth gear is not needed.
Unread 03-12-2014, 12:08 AM   #12
baritone_mike
What I am telling you is the stock speedo gear on a 4 banger manual YJ is 41 tooth.
Unread 03-12-2014, 12:23 AM   #13
wrangler_bear
Oh **** !!! Thanks buddy. You just saved me some money. I was using a phone app speedometer for comparison. Appears to be pretty dang close.
Unread 03-17-2014, 08:31 PM   #14
wrangler_bear
Took gear out and yes....you are right. There's a 41 tooth gear already in there. Thanks for the tip.
