Vehicle Vibration - JeepForum.com
post #1 of 9 Old 09-20-2013, 06:15 PM Thread Starter
JEEPSC
Vehicle Vibration
I'm having a bad vibration at the top of 2 and bottom of third mostly. Though all gears do it some. It's only under load because when i let off the peddle the vibration goes away. It shakes the whole jeep pretty much. Ive changed the plugs, wires and fuel filter in hopes that it was just some sort of hesitation problem but now I'm at a loss. HELP! This is my DD. Thanks.
JEEPSC is offline
post #2 of 9 Old 09-20-2013, 06:23 PM
Apollo12227
Did this start all at once? Recently? Do you feel the vibration the most in your seat or in your hands (through the wheel)?
Apollo12227 is offline
post #3 of 9 Old 09-20-2013, 06:32 PM Thread Starter
JEEPSC
Yes it just started today. Thought id add i only have a shackle lift so i dont think its a driveline alignment issue. I can feel it in the seat the steering wheel and through my feet.
Shackle Lift-32x11.5 BFG All terrains
JEEPSC is offline
post #4 of 9 Old 09-20-2013, 06:53 PM
Apollo12227
A shackle lift still effects the drivline angle, any change in suspension (ride height) changes this angle... A body lift would have no effect. All of that aside, I agree that a shakle lift shouldn't be causing this issue, especially all at once.
The usual start is going to be the driveshaft ujoints. You'll need to chuck the tires, place the heep in neutral, and crawl under to check the drive shaft for forward and aft play, as well as side to side play. Any play at all, especially near the pinion, would point towards a failing ujoint.
If you have an SYE you can remove the rear drive shaft, drive the heep in 4wd and see if there is a difference. This will allow you to eliminate rear ujoints as the problem entirely.
Vibrations can also come from the front axle shaft ujoints, the are somewhat harder to inspect. I'm sure some of our more tenured folks will be in here soon to offer adtl advise.
Good luck!
post #5 of 9 Old 09-20-2013, 08:05 PM Thread Starter
JEEPSC
Ok I'll just go ahead and swap the u joints tomorrow thanks for the advice.
JEEPSC is offline
post #6 of 9 Old 09-20-2013, 09:19 PM Thread Starter
JEEPSC
Another question, would bad u joints on the rear drive shaft cause pre mature failure of the transfer case output shaft seal?
JEEPSC is offline
post #7 of 9 Old 09-26-2013, 09:32 PM
Robob69
If you have the seal going bad real fast as I did on my 95 YJ it was the rear OP shaft was bent and thus caused a bad Vibration.
I changed Axle Shafts U joints, Drive Shaft and Still was there...
Then the Awesome people here told me about the Shaft.. Sure enough!!! Fixed it...
If you done have an SYE pull the drive shaft and put the tranny in Neutral and spin the shaft and watch it to see if there is ANY wobble at all...
But yes your U joints can cause the seal as well to go bad if there is enough vibration..
Hope this helps a bit...
Robob69 is offline
post #8 of 9 Old 10-30-2013, 08:03 PM Thread Starter
JEEPSC
Yes it does thank you.
JEEPSC is offline
post #9 of 9 Old 10-30-2013, 08:49 PM
ROTTEN
Check engine and trans mounts as well. I had a rocky time on flat pavement because of blown engine mounts
I'm new
ROTTEN is offline
