VamosJeep's Build Thread - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > VamosJeep's Build Thread
KrawlOff-Road.com Sale EventFS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light Ba
Unread 03-25-2009, 12:48 PM   #1
VamosJEEP
I have lurked around JeepForum for a lil while now and decided I should put up my "build" Thread.
Purchased the jeep in 06' after it was in an accident. Got it running in the summer of 07' then realized at the end of summer that my frame was going to need replaced instead of patching every bit I could.
Doner frame out of an 89 sahara. $200 at the junkyard
Start of the tear down Feb of 07'
Rebuild started beginning of March 07'
Started to Paint
Jeep originally had 37's with 3.07 I steped it down to 35's then eventually down to 33's
As of a month ago I swapped in a 8.8 lsd and a built hp d30 with cromoly shafts/ Aussie locker and 35" MTRs
As she sits now
I know after doing this every part of my vehicle through and through. My suggestion if you need to replace a frame... FIND A NEW JEEP! lol
My Build Thread
2010-2012 Pres of: CLICK--->EASTERN SHORE JEEP ASSOCIATION<---CLICK Based out of Salisbury, MD
"Help your fellow jeeper out when they are in need because the Jeep gods may look down upon you and reward you for your effort."
VamosJEEP is offline   Reply With Quote Quick reply to this message
Unread 03-25-2009, 12:51 PM   #2
Ptr
1992 J-Series Truck
Started to Paint
As she sits now
clicka free
Ptr is offline   Reply With Quote Quick reply to this message
Unread 03-25-2009, 12:53 PM   #3
VamosJEEP
Thanks
I forgot to mention... I have put a deposit on my roll cage!
My Build Thread
Unread 03-25-2009, 01:00 PM   #4
kmart
-I know after doing this every part of my vehicle through and through. My suggestion if you need to replace a frame... FIND A NEW JEEP! lol
I would agree with you there!! I just completed a frame swap on my 88 YJ that I hope to post in a build thread soon. The frame was totally rusted out, and hindsight being 20/20, it would have been much easier to find a different jeep. But you do gain a lot of experience for future projects.
Red Jeep Club Member #541
Low Output 4 Cylinder Jeep Club Member #179
kmart is offline   Reply With Quote Quick reply to this message
Unread 03-25-2009, 01:46 PM   #5
Maryland95YJ
i love it, and i agree with the frame, I had the option to buy a 86 cj7 for 500 bucks but turned it down due to rotten frame, The guy that did buy it ended up stranded on a trail. he did not check out the frame before buying and ended up breaking it right above the drivers side rear axle.
Maryland95YJ is offline   Reply With Quote Quick reply to this message
Unread 03-25-2009, 01:54 PM   #6
VamosJEEP
Ouch. I knew there were some bad spots on the frame when I bought it. I knew the infamous frame rot wasn't going to go away so I figured I would just cough up the $200 and buy a good frame.
I have bought rusted out CJ's just to turn around and part them out. I know now there is no use to try to repair body or frame rot. lol
Thanks for your comments
My Build Thread
Unread 03-25-2009, 02:51 PM   #7
VamosJEEP
Here are some wheelin pics/vids
My Build Thread
Unread 03-25-2009, 02:56 PM   #8
jakechristina
Looks good
I'm Glad to see that you remained hydrated during your work! Thats very important
jakechristina is offline   Reply With Quote Quick reply to this message
Unread 03-25-2009, 09:25 PM   #9
VamosJEEP
Thanks. Hydration is #1 in my book. lol
My Build Thread
Unread 05-10-2009, 08:52 PM   #10
VamosJEEP
Lil update:
I picked up a cage built by a local shop that builds monster trucks. It was installed in another jeep when I picked it up. Used but never tested lol. I liked the overall build but I thought it needed some more. It came with 2 corbeau full suspension seats and 2-5 pt harnesses. Its an 8 point cage. The cage will be getting tied into the frame on all 8 points. Here are some pics.
The new bars installed. The red parts are the cage before the extra bars were put in.
Then I sanded and painted the whole thing. The cage was painted with Krylon ultra flat Khacki.
I will post pics as the install comes along. Will possibly have it done by the end of the week.
My Build Thread
Unread 05-11-2009, 08:17 PM   #11
VamosJEEP
Mocked it into the jeep. Still need to do some modifying. Looks like the dash pad will be getting pulled out to get it to sit down all the way. Will post more pics as the install comes along.
My Build Thread
Unread 05-11-2009, 08:34 PM   #12
thetrashman
I<3Your Jeep
95' Little Red Yj.
"My Jeep Doesnt Leak, Its Just Marking Its Territory"
Mostly Stock,With A Few Things
My Build Thread
thetrashman is offline   Reply With Quote Quick reply to this message
Unread 05-11-2009, 08:48 PM   #13
tato1111
did your rear corners affect the tj flare swap as far as getting in the way with grinding?
tato1111 is offline   Reply With Quote Quick reply to this message
Unread 05-11-2009, 08:57 PM   #14
VamosJEEP
Thanks Trashman!
The corners are aluminum. More for show than anything else so they were easily trimed.
My Build Thread
Unread 05-11-2009, 09:10 PM   #15
tato1111
^^^i have diamond plate ones like that so should i expect to trim them?
