valve cover bolt pattern - JeepForum.com
post #1 of 10 Old 07-06-2013, 05:35 PM Thread Starter
vrxagjf
Okay, I made the simple mistake of not noting where the studs are on my 1995 YJ 2.5L when removing the valve cover. Can someone look at theirs and post the pattern? Please be specific as there are bolts, studs, and studs with nuts (11 total). I found a post with the 4.0 pattern, but not the 2.5 pattern. Thanks, Greg.
vrxagjf is offline
post #2 of 10 Old 07-18-2013, 08:10 AM Thread Starter
vrxagjf
Can anyone answer this please? Seems an easy enough answer if you just look at your engine.
vrxagjf is offline
post #3 of 10 Old 07-18-2013, 08:36 AM
grandboost98
I would like to help you but the early 2.5s use a different valve cover, therefor may have a different pattern.
Free bump
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #4 of 10 Old 07-18-2013, 08:45 AM
Siva283
On mine I remember the 4 corners had studs and the 2 on the drivers side were the studs with nuts on them. I think there is one other. I dont have the jeep at work so I cant run out and check. But if I remember correctly there were a total of 5 studs 3 without nuts and 2 with nuts on them. The rest were bolts.
Ask me how I know...
Siva283 is offline
post #5 of 10 Old 07-20-2013, 10:18 AM Thread Starter
vrxagjf
Thanks Siva. That's a start. Is your's a '95? If you get time and can look at it to verify pattern, I'd appreciate it.
vrxagjf is offline
post #6 of 10 Old 07-20-2013, 04:43 PM
Siva283
Yes mine is a 95. I will snap a pic for you when I get home in a bit
Sent from my SPH-L300 using JeepForum
Siva283 is offline
post #7 of 10 Old 07-23-2013, 04:27 PM Thread Starter
vrxagjf
Siva, any update? Thanks,
Greg
vrxagjf is offline
post #8 of 10 Old 07-23-2013, 07:59 PM
Siva283
Greg
Crap sorry dude I forgot to get the pic. On mine though looking at it there is a stud on each corner the back drivers side is a stud with a nut the body ground strap attaches to it. The front drivers side is a stud with a nut a braket attaches to it The two center spots on the drivers side are studs as well. The rest are bolts.
Siva283 is offline
post #9 of 10 Old 07-23-2013, 08:04 PM
Siva283
I just tried taking a pic. I don't know if its dark or my camera sucks but I can't get it to show up well enough to where you can tell the bolts from the studs.
Siva283 is offline
post #10 of 10 Old 07-24-2013, 03:26 PM Thread Starter
vrxagjf
Siva, I think your description should get it. Thanks!
vrxagjf is offline
