Valve Cover ? - JeepForum.com
post #1 of 4 Old 03-04-2002, 05:36 PM Thread Starter
RCHavok797
RCHavok797's Avatar
Valve Cover ?
I went to my local chrysler dealership today to get a new valve cover gasket for my 4.0 91 Wrangler and I find out that there is no gasket for it. The valve cover is just sealed down. I wanted to fix the oil leak coming from the valve cover so I guess I will have to just reseal it. But my question is do any of the 4.0L engines come with a valve cover gasket or is there a way to get one? Thanks in advance.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline
post #2 of 4 Old 03-05-2002, 12:17 AM
kidwired
kidwired's Avatar
gaskets suck, I havent used em in 20yrs, from hotrods to hardcore rigs. just 1 more seam to leak from. its all about the ATV baby.
94 yj SOA +3.5", 35" swampers.
kidwired is offline
post #3 of 4 Old 03-05-2002, 04:40 PM Thread Starter
RCHavok797
RCHavok797's Avatar
good point, thanks.
post #4 of 4 Old 03-06-2002, 11:07 AM
89 YJ
Get an aluminum cover. Put small amount of sealer in cover only and let it tack up and insert gasket into it. Then put cover on and dont overtighten it. Check thightness of it for a few weeks to make sure it doesnt get lose after driving. Worked on mine.
89 YJ Islander, AC,PS, 10 inch lift, 32 BFG MT's, sway quick disconnect, rear track bar quick disconnect, 400 watt 12 speaker cd player for tunes,8000lb warn 8274 with 150 ft cable, and a high lift jack.. Lockers, 35's, webber carb and jacobs ignition comming soon.
89 YJ is offline
CCV Fitting, Valve cover to Manifold Cover need help skd+ROO TJ Wrangler Technical Forum 0 11-08-2009 03:13 PM
Broke elbow on pcv valve on front of valve cover... 99JeepWrangler TJ Wrangler Technical Forum 12 01-01-2009 01:17 PM
93, 4 Cyl, YJ Valve Cover Leaking = New Valve Cover?! Jim93YJ YJ Wrangler Technical Forum 10 09-12-2007 03:33 PM
87 valve cover alienball YJ Wrangler Technical Forum 22 06-29-2006 09:18 AM
Valve Cover mitchj01 YJ Wrangler Technical Forum 9 09-01-2002 10:03 AM
