valve adjustment - JeepForum.com
post #1 of 7 Old 10-01-2005, 02:05 PM Thread Starter
diesel158
valve adjustment
I did a search but didn't come up with what I'm looking for. Valve cover was leaking so I pulled it to replace the gasket,of course the plastic cover is full of cracks so that's gotta go.While I have the cover off I figured I'd adjust the valves but there is a clip that joins the rockers together on each cylinder so they can't be adjusted independently.How are they adjusted? Also,1 push rod is turning a little slow. Thanks
leave the gun,take the canoli's
diesel158 is offline
post #2 of 7 Old 10-01-2005, 11:08 PM
sloth665
What year is your jeep and what
engine is in it?
sloth665 is offline
post #3 of 7 Old 10-02-2005, 12:02 AM
Cobra Jeep
Umm, if they are the bridged type rockers you speak of, then they are not adjustable. The bolts are simply torqued down to spec and thats it, no adjustment.
'93 YJ 4.0L, AX-15, NP-231HD/SYE, 8.8in rear, OME 2.5 lift, home made front hub conversion, hydroboost. Warn M10000 winch. Currently building a stroker.
'79 Cherokee Chief, 401 MPFI fuel injection, T-18/D-20 and hydroboost. Otherwise stock.
Cobra Jeep is offline
post #4 of 7 Old 10-02-2005, 08:47 AM Thread Starter
diesel158
it's an '87 with the 4.2. Not being able to adjust the valves is a real bad design.I know they sell a roller rocker kit for that engine,what's the point in not being able to adjust them? There has to be a way.
post #5 of 7 Old 10-02-2005, 11:10 AM
91GTA350
If i am not mistaken our engines have hydraulic lifters. I think the lifters are suposed to have some sort of automatic adjustment.
-89 sahara 258: HAD a peugot and a d35
5/15/05 - took ownership and started money pit
9/17/05 - found a 3.5' deep water hole
2/18/06 - destroyed spiders in d35
4.2/AX-15/NP-231/SYE/30/8.8/3.55/RE 2.5"/31"
91GTA350 is offline
post #6 of 7 Old 10-02-2005, 12:27 PM Thread Starter
diesel158
yes,we have hydraulic lifters but they should be adjustable through the rockers.
post #7 of 7 Old 10-02-2005, 08:08 PM
Cobra Jeep
Nope, no adjustment. You just torque them down to spec and go. All jeep 2.5's, 4.2's, 4.0's, and AMC V8's (304-360-401) are like that.
4.2 valve adjustment help Zangief YJ Wrangler Technical Forum 2 07-26-2009 02:47 PM
Throttle Valve Linkage adjustment? TEXASRAM YJ Wrangler Technical Forum 0 08-08-2005 02:44 PM
Valve Adjustment on the 4.0 wrangler2002 TJ Wrangler Technical Forum 1 09-30-2004 10:55 AM
Valve adjustment Our TJ TJ Wrangler Technical Forum 4 12-22-2003 12:49 PM
valve adjustment mv971 YJ Wrangler Technical Forum 1 07-02-2003 06:59 AM
