vacuum routing assistance(CTO) needed - JeepForum.com
post #1 of 10 Old 03-25-2008, 07:45 PM Thread Starter
schwim
Hey there guys,
Info is tight in the YJ camp for some aspects of the vac system, in particular the CTO valve and evap canister.
I'm wondering if I can use the diagram in this thread to go by. I ask because everything I read told me to cap the one unused port on the CTO valve, while this guy's diagram leaves it open. I have Elvis' diagram as well, but it doesn't label the evap can at all, and he doesn't tell whether to plug the 5th port or leave it open.
In another thread, someone stated that the canister is labeled for which lines go where, so I'll try to find them tomorrow.
thanks,
json
BOUGHT. Not Built.
schwim is offline
post #2 of 10 Old 03-25-2008, 07:49 PM
Crash1
Look here http://home.sprynet.com/~dale02/list.htm
89 RED YJ, fresh rebuilt 4.2L , Howell TBI, HEI, 2.5"RE HD Lift, 1" BL, 31" TIRES
Crash1 is offline
post #3 of 10 Old 03-25-2008, 07:56 PM Thread Starter
schwim
Got it already, thanks. It only adds to the fact that nobody can agree on anything, once the vac system has been modified by nutters and carb mods.
5th port, capped or not?
thanks,
json
BOUGHT. Not Built.
schwim is offline
post #4 of 10 Old 03-25-2008, 09:28 PM
jbolty
jbolty's Avatar
most diagrams don't mention that extra port but the instructions I got with my howell kit specifically say that it's a vent and left open.
jbolty is offline
post #5 of 10 Old 03-25-2008, 10:01 PM Thread Starter
schwim
That's awesome, man. Thanks very much for that.
thanks,
json
BOUGHT. Not Built.
schwim is offline
post #6 of 10 Old 03-26-2008, 12:53 PM
timatoe
timatoe's Avatar
I run mine just like the sprynet site, but tapped off of the ported line for the distributor after doing the Nutter.
I take it that CTO made it safely??
timatoe is offline
post #7 of 10 Old 03-26-2008, 05:38 PM Thread Starter
schwim
Indeed Tim, thanks very much.
I'm not sure what you mean about tapping off of the ported after doing the nutter. What changed for you from sprynet's or Elvis' diagram post-nutter?
thanks,
json
BOUGHT. Not Built.
schwim is offline
post #8 of 10 Old 03-26-2008, 09:06 PM
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
All the CTO valve does is prevent ported vacuum from reaching the EGR and canister before the engine is warmed up. It's just a valve that opens between the vacuum source (the engine) and the devices that use it (EGR and Canister) after the engine has reached a certain temperature. The extra port comes sealed from the factory... I don't really see the advantage of opening it up. At best, if the port isn't connected to anything, opening it will do absolutely nothing. At worst, if the port connects to the others, it will create an enormous vacuum leak.
As for the canister ports, they are labeled on the top of the housing. The Howell diagram above looks correct, execpt the one marked "tab" would be connected to your carb vent (if your carb has one). I would check the top of the canister to be sure though.
- 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
- Donated drive train to the YJ, Parted out the rest
- Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline
post #9 of 10 Old 03-26-2008, 09:14 PM Thread Starter
schwim
Originally Posted by Tshark299 View Post
....At best, if the port isn't connected to anything, opening it will do absolutely nothing. At worst, if the port connects to the others, it will create an enormous vacuum leak.
Heya tshark, and thanks very much for your reply.
That was my concern. I just didn't want to introduce a huge vac leak once it warmed up
One more question. Is the CTO valve install a compression fit only, or do I need to use a sealant of some kind?
thanks,
json
BOUGHT. Not Built.
schwim is offline
post #10 of 10 Old 03-26-2008, 11:15 PM
timatoe
timatoe's Avatar
thanks,
json
I wasn't clear. I used a "T" fitting in the line going back to the distributor vacuum advance. I just used it as the ported source, because I need all my crap to still look stock to pass CA emissions.
timatoe is offline
Vacuum hose routing logiplex YJ Wrangler Technical Forum 2 04-19-2013 09:10 PM
4wd vacuum motor hose routing? TorqueWrench87 YJ Wrangler Technical Forum 8 03-10-2011 03:51 PM
Need routing to replace vacuum line on driver's side tweba99 TJ Wrangler Technical Forum 7 09-14-2007 01:40 PM
axle vacuum motor tube routing mbosco1 YJ Wrangler Technical Forum 12 09-09-2005 05:36 PM
??? Vacuum routing question ??? Bob K YJ Wrangler Technical Forum 3 02-28-2002 07:28 AM
